Datasheet Texas Instruments UC3872DWTRG4 — Даташит
СерияUC3872
МодельUC3872DWTRG4
Контроллер резонансного лампового балласта 16-SOIC от 0 до 70
Resonant Lamp Ballast Controller datasheet
PDF, 381 Кб, Файл опубликован: 5 сен 1999
Pin16
Package TypeDW
Package QTY2000
МаркировкаUC3872DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Control TopologyPush-Pull
Frequency(Max)200 kHz
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Shutdown Current1 мА
Special FeaturesExternal Sync,Lamp Intensity Control,Open Lamp Detect,Soft Start
Ток потребления11 мА
Vin(Max)24 В
Vin(Min)4.5 В
  • DN-75 Using the UC3871 and UC3872 Resonant Fluorescent Lamp Drivers in Floating
    PDF, 160 Кб, Файл опубликован: 5 сен 1999
    The UC3871 and UC3872 family of resonant lamp drivers contains all of the necessary control circuitry to implement a highly efficient, cold-cathode. fluorescent back-light driver. This design note de-scribes how to modify the circuit to accommodate a floating-lamp topology.
  • U-141 Resonant Fluorescent Lamp Converter Provides Efficient and Compact
    PDF, 210 Кб, Файл опубликован: 5 сен 1999
    The UC3871 IC is optimized for highly efficient fluorescent lamp control. An additional PWM controller is integrated on the IC for applications requiring an additional supply, as in LCD displays. The switching frequency of all outputs is synchronized to the resonant frequency of the external passive network, which provides Zero Voltage Switching (ZVS) on the push-pull drivers. This paper describ
  • U-148 Dimmable Cold-Cathode Fluorescent Lamp Ballast Design Using the UC3871
    PDF, 380 Кб, Файл опубликован: 5 сен 1999
    The UC1871 family of ICs is optimized for highly efficient fluorescent lamp control. An additional PWM controller is integrated on the IC for applications requiring an additional supply, as in LCD displays. This application note describes how to design a resonant cold-cathode fluorescent lamp converter and liquid crystal display (LCD) bias supply using the UC3871. This note discusses a design meth
  • Semiconductors > Power Management > Power Management Special Functions > CCFL Backlight Controller
На английском языке: Datasheet Texas Instruments UC3872DWTRG4
