Datasheet Texas Instruments UC3903DWTRG4 — Даташит
Серия | UC3903 |
Модель | UC3903DWTRG4 |
Quad Supply and Line Monitor 18-SOIC 0 to 70
Quad Supply and Line Monitor datasheet
PDF, 796 Кб, Версия: A, Файл опубликован: 26 авг 2008
Купить UC3903DWTRG4 на РадиоЛоцман.Цены — от 186 до 289 ₽ 9 предложений от 9 поставщиков Processor Supervisor Adj 4 Active Low/Open Drain 18Pin SOIC | |||
UC3903DWTRG4 Texas Instruments | 186 ₽ | ||
UC3903DWTRG4 Texas Instruments | 257 ₽ | ||
UC3903DWTRG4 Texas Instruments | 260 ₽ | ||
UC3903DWTRG4 | по запросу |
Pin | 18 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | UC3903DW |
Width (мм) | 7.5 |
Length (мм) | 11.5 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
# of Supplies Monitored | 4 |
Iq(Typ) | 7000 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable В |
Monitored Voltage 2 (typ)(Nom) | Adjustable В |
Рабочий диапазон температур | от 0 до 70 C |
Output Driver Type / Reset Output | Active-low,Open-drain |
Package Group | SOIC |
Package Size: mm2:W x L | 18SOIC: 119 mm2: 10.3 x 11.55(SOIC) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 5 % |
Special Features | Negative Voltage Monitoring,Over Voltage Sense |
Threshold Voltage 1(Typ) | 1.8 В |
Threshold Voltage 2 (typ)(Typ) | Adjustable В |
Time Delay | Programmable ms |
VCC(Max) | 40 В |
VCC(Min) | 8 В |
Watchdog Timer WDI | None sec |
- DN-33 Optocoupler Feedback Drive Techniques Using the UC3901 and UC3903PDF, 45 Кб, Файл опубликован: 5 сен 1999
A variety of low-cost supervisory ICs contain the required building blocks for the more demanding optocoupler feedback drive applications. Initially developed to address other specific power supply tasks several control ICs excel in the role as precision optocoupler control and drivers. This design note describes a basic optocoupler driver circuit and also a more advanced optocoupler drive circ - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
Серия: UC3903 (5)
- UC3903DW UC3903DWTR UC3903DWTRG4 UC3903Q UC3903QG3
- Semiconductors > Power Management > Supervisor and Reset IC
