Datasheet Texas Instruments BUF601AU — Даташит
СерияBUF601
МодельBUF601AU
Высокоскоростной буферный усилитель 8-SOIC
Datasheet
TSP
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementOPA692ID
Replacement CodeP
RoHSНе совместим
  • Macromodels for RF Op Amps Are a Powerful Design Tool
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The macromodel for the Diamond Transistor OPA660 gives an example of the structure and performance of these new Spice models.
  • Designing Active Filters with the Diamond Transistor OPA660
    PDF, 114 Кб, Файл опубликован: 27 сен 2000
    Signal frequency bandwidth limitation, fast pulse shaping, separation between telecommunications signals, and suppression of unwanted carrier and disturbance frequencies are among the most important jobs of filter circuits. While active filters with operational amplifiers and switched capacitor filters are used for lower frequency applications, passive filter versions dominate the application spec
  • There's a World Of Line Drivers to Choose From
    PDF, 62 Кб, Файл опубликован: 2 окт 2000
    Coax cables with a typical impedance of 50О© or 75О© are used in many applications to ensure signal fidelity, and high-speed line drivers have the often difficult job of transmitting signals over these cables or over twisted pair lines. The most common way to drive coax cables is to use driver amplifiers with low-impedance voltage output, which operate with either voltage or current feed
Серия: BUF601 (2)
На английском языке: Datasheet Texas Instruments BUF601AU
