Datasheet Texas Instruments UCC3913D — Даташит
Серия | UCC3913 |
Модель | UCC3913D |
Negative Floating Single, Hot-Swap IC Commercial Temp. 8-SOIC 0 to 70
Negative Voltage Hot Swap Power Manager datasheet
PDF, 820 Кб, Версия: A, Файл опубликован: 5 мар 2003
Купить UCC3913D на РадиоЛоцман.Цены — от 153 до 711 ₽ 19 предложений от 16 поставщиков Горячая замена и распределение питания Neg Floating Single Commercial Temp. | |||
UCC3913D Texas Instruments | 153 ₽ | ||
UCC3913D Texas Instruments | 167 ₽ | ||
UCC3913D Unitrode | по запросу | ||
UCC3913D8P Texas Instruments | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 75 |
Carrier | TUBE |
Маркировка | UCC3913 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Channel(s) Controlled | 1 |
Current Limit Accuracy | +/- 15% @ 100 mV,+/- 7.5% @ 400 mV |
Current Limit Function Enabled | Always |
Current Limit Threshold(Typ) | Adjustable Ext FET=mV |
Current Measurement Accuracy | N/A % |
Design Support | Calculation Tool |
Fault Response | Auto Retry |
ON_OFF Control Input | SD/FLT s |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Special Features | Ultra High Voltage |
Status Output | SD/FLT |
Vabsmax_cont | -9999 В |
Vin(Max) | -10.5 В |
Vin(Min) | -9999 В |
- A Power Management Interface Circuit for Telecom Hot Swap with Local DC/DC ConvePDF, 467 Кб, Файл опубликован: 16 апр 2001
Today, the brains of telecom and datacom systems - i.e., microprocessors, DSPs, ASICs, and programmable logic - are evolving to ever-lower operating voltages. Typical ICs run at supply levels of 3.3 V, 2.5 V, and even lower. As this occurs, new devices and modules are being developed to address the functions of hot-swapping the standard ?48 Vdc bus, and subsequent conversion to local regulation l - Simplified Solutions for Hot Swap Power Management in Telecom SystemsPDF, 101 Кб, Файл опубликован: 20 июл 2001
Engineers designing plug-in or adapter cards for the ?48-Vdc distribution environment often need an efficient, cost-effective means of implementing hot swap capability. Hot swap solutions vary in complexity, some adding features for system or operator control and interface or other related functions. However, it is ultimately the basic function of applying input power to the module?s bulk capacita
Серия: UCC3913 (2)
- UCC3913D UCC3913DG4
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
