Datasheet Texas Instruments OPA660AU — Даташит
СерияOPA660
МодельOPA660AU
Широкополосный операционный усилитель крутизны и буфер 8-SOIC
Datasheet
TSP
15 предложений от 15 поставщиков
Микросхема Операционный усилитель, SP Amp Transconductance Amplifier Single ±5.5V 8Pin SOIC Tube
OPA660AU
128 ₽
OPA660AU
170 ₽
OPA660AU/2K5
262 ₽
727GS
OPA660AU
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Improved Noise Performance of the ACF2101 Switched Integrator
    PDF, 42 Кб, Файл опубликован: 27 сен 2000
    The signal-to-noise ratio and bandwidth of the combination of the ACF2101 dual, switched integrator and a low-level input current is exceptional when compared to the performance of a classical transimpedance amplifier. To further improve the ACF2101 signal-to-noise ratio, a resistor can be added in series with the input sensor.
  • Fiber Optic Transmission
    PDF, 81 Кб, Файл опубликован: 27 сен 2000
    Fiber optic transmission is assuming an increasingly important role in systems for wide-band analog signals and digital signals with high data rates. Although the number of applications for digital networks and telecommunications systems is skyrocketing, analog transmission is still vital to many applications. Analog systems with bandwidths of up to 150MHz are used for wide-band RGB signal distrib
  • New Ultra High-Speed Circuit Techniques with Analog ICs
    PDF, 160 Кб, Файл опубликован: 27 сен 2000
    With the increasing use of current-feedback amplifiers, the Diamond Structure has come to play a key role in today's analog circuit technology. Two new macro elements that function in this structure are the Diamond Transistor and its abridged version, the Diamond Buffer. These elements can be used for both voltage and current control of analog signals up to several 100MHz. The OPA660 combines both
  • Automatic Gain Control (AGC) Using the Diamond Transistor OPA660
    PDF, 150 Кб, Файл опубликован: 2 окт 2000
    Multiplication of analog signals has long been one of the most important nonlinear functions of analog circuit technology. Many signal sources, however, such as CCD sensors, pin diodes, or antennas, deliver weak, oscillating, and simultaneously wide-band signals. But now a new multiplication method is available. Used as a wide-bandwidth Automatic Gain Control (AGC) application circuit, the integra
  • OPA660 Drives Magnetic Recording Head
    PDF, 37 Кб, Файл опубликован: 2 окт 2000
    The OPA660 is a unique solution to many high-speed design problems. It offers the high-speed and wide-bandwidth of discrete transistors necessary for RF, IF, and video circuitry while maintaining the simplicity, reliability,and ease-of-use of a monolithic, integrated circuit. For applications where neither an op amp nor a discrete transistor quite fit, the OPA660 may be exactly what your're lookin
  • Building a 400MHz Wide-Band Differential Amp: With the Diamond Transistor OPA660
    PDF, 48 Кб, Файл опубликован: 27 сен 2000
    The OPA660 makes it easy to design a 400MHz differential amplifier offering ?60dB common-mode rejection at a 1MHz frequency. This amplifier uses an open-loop amplifier structure with two identical high-impedance inputs and no feedback. The parameters such as wide bandwidth, stable operation, and excellent pulse processing, common-mode rejection, and harmonic distortion let the performance speak fo
  • Diamond Transistor OPA660
    PDF, 84 Кб, Файл опубликован: 2 окт 2000
    The monolithic integrated circuit OPA660 uses the Diamond structure to act as an ideal transistor. However, this circuit has the advantage that it avoids the biasing circuits and eliminates the need for an offset voltage compensation network. With this element, peripheral components are reduced to the essential minimum. Using the DC-coupled wideband voltage amplifier and buffer, conventional and n
  • Macromodels for RF Op Amps Are a Powerful Design Tool
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The macromodel for the Diamond Transistor OPA660 gives an example of the structure and performance of these new Spice models.
  • Designing Active Filters with the Diamond Transistor OPA660
    PDF, 114 Кб, Файл опубликован: 27 сен 2000
    Signal frequency bandwidth limitation, fast pulse shaping, separation between telecommunications signals, and suppression of unwanted carrier and disturbance frequencies are among the most important jobs of filter circuits. While active filters with operational amplifiers and switched capacitor filters are used for lower frequency applications, passive filter versions dominate the application spec
  • There's a World Of Line Drivers to Choose From
    PDF, 62 Кб, Файл опубликован: 2 окт 2000
    Coax cables with a typical impedance of 50О© or 75О© are used in many applications to ensure signal fidelity, and high-speed line drivers have the often difficult job of transmitting signals over these cables or over twisted pair lines. The most common way to drive coax cables is to use driver amplifiers with low-impedance voltage output, which operate with either voltage or current feed
  • Video Operational Amplifier
    PDF, 107 Кб, Файл опубликован: 2 окт 2000
    In analog technology, important advances are being made in video operational amplifiers, both in processing and in circuitry. The following article is concerned exclusively with explaining these key topics and the new circuit designs.
Серия: OPA660 (3)
На английском языке: Datasheet Texas Instruments OPA660AU
