Datasheet Texas Instruments UCC3921DTR — Даташит
СерияUCC3921
МодельUCC3921DTR
Защелкивающийся отрицательный плавающий одиночный, горячая замена ИС Коммерческая температура 8-SOIC от 0 до 70
Latchable Negative Floating Hot Swap Power Manager datasheet
PDF, 1.1 Мб, Файл опубликован: 5 сен 1999
Package TypeD
Package QTY2500
МаркировкаUCC3921
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Channel(s) Controlled1
Current Limit Accuracy+/- 15% @ 100 mV,+/- 7.5% @ 400 mV
Current Limit Function EnabledAlways
Current Limit Threshold(Typ)Adjustable Ext FET=mV
Current Measurement AccuracyN/A %
ON_OFF Control InputSDFLTCH s
Special FeaturesUltra High Voltage
Status OutputSDFLTCH
Vabsmax_cont-9999 В
Vin(Max)-10.5 В
Vin(Min)-9999 В
  • A Power Management Interface Circuit for Telecom Hot Swap with Local DC/DC Conve
    PDF, 467 Кб, Файл опубликован: 16 апр 2001
    Today, the brains of telecom and datacom systems - i.e., microprocessors, DSPs, ASICs, and programmable logic - are evolving to ever-lower operating voltages. Typical ICs run at supply levels of 3.3 V, 2.5 V, and even lower. As this occurs, new devices and modules are being developed to address the functions of hot-swapping the standard ?48 Vdc bus, and subsequent conversion to local regulation l
  • Simplified Solutions for Hot Swap Power Management in Telecom Systems
    PDF, 101 Кб, Файл опубликован: 20 июл 2001
    Engineers designing plug-in or adapter cards for the ?48-Vdc distribution environment often need an efficient, cost-effective means of implementing hot swap capability. Hot swap solutions vary in complexity, some adding features for system or operator control and interface or other related functions. However, it is ultimately the basic function of applying input power to the module?s bulk capacita
Серия: UCC3921 (4)
  • Semiconductors > Power Management > Protection, Monitoring and Hot Swap > Hot Swap Controllers (Positive, -48V)
На английском языке: Datasheet Texas Instruments UCC3921DTR
