Datasheet Texas Instruments TPA3003D2PFB — Даташит
СерияTPA3003D2
МодельTPA3003D2PFB
Стереоусилитель мощности звука класса D, 3 Вт с регулятором громкости (TPA3003) 48-TQFP от -40 до 85
TPA3003D2: 3-W Stereo Class-D Audio Power Amplifier w/DC Volume Control datasheet
PDF, 913 Кб, Версия: A, Файл опубликован: 18 мар 2003
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (5+1)
МаркировкаTPA3003D2
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Analog Supply (V)5 Min
Audio Input TypeAnalog Input
Closed/Open LoopClosed
Control InterfaceHardware
Package GroupTQFP
Package Size: mm2:W x L48TQFP: 81 mm2: 9 x 9(TQFP) PKG
Power Stage Supply(Max)14 В
Speaker Channels2 Max
  • Evaluation Modules & Boards: TPA3003D2EVM
    TPA3003D2 Evaluation Module (EVM)
  • Layout Guidelines For TPA300x Series Parts
    PDF, 647 Кб, Файл опубликован: 15 июл 2003
    This article provides a well-reinforced procedure for the PCB layout task as it pertains to the TPA300x series of class D amplifiers. This information can also be used in the layout of the TPA200x series, or any other class D audio amplifier.This task needs a logical sequence. If we simply jump into the layout task, without understanding how the circuits work, we risk not having an optimal end
Серия: TPA3003D2 (4)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3003D2PFB
