Datasheet Texas Instruments TPA3004D2PHPR — Даташит
СерияTPA3004D2
МодельTPA3004D2PHPR
Усилитель мощности звука StereoClass-D 12 Вт с регулятором громкости (TPA3004) 48-HTQFP от -40 до 85
12W Stereo Class-D Audio Power Amp w/DC Volume Control datasheet
PDF, 947 Кб, Версия: E, Файл опубликован: 10 янв 2010
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаTPA3004D2
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Analog Supply (V)18 Min
Audio Input TypeAnalog
Closed/Open LoopOpen
Control InterfaceHardware
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
Power Stage Supply(Max)18 В
Power Stage Supply(Min)8.5 В
Power to Bridge Tied Load(Max)12 W
Speaker Channels2 Max
Supported Bridge Tied Load(Min)4 Ohms
  • Evaluation Modules & Boards: TPA3004D2EVM
    TPA3004D2 Evaluation Module (EVM)
  • RC Filter Box For Class-D Output Power and THD+N Measurement
    PDF, 636 Кб, Файл опубликован: 20 фев 2004
  • Layout Guidelines For TPA300x Series Parts
    PDF, 647 Кб, Файл опубликован: 15 июл 2003
    This article provides a well-reinforced procedure for the PCB layout task as it pertains to the TPA300x series of class D amplifiers. This information can also be used in the layout of the TPA200x series, or any other class D audio amplifier.This task needs a logical sequence. If we simply jump into the layout task, without understanding how the circuits work, we risk not having an optimal end
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3004D2 (4)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3004D2PHPR
