Оптопары и оптореле Megawin
Datasheet Texas Instruments ULN2003ANSRG4 — Даташит
СерияULN2003A
МодельULN2003ANSRG4
Высоковольтные, сильноточные транзисторные массивы Дарлингтона 16-SO -20 до 70
ULN200x, ULQ200x High-Voltage, High-Current Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: O, Файл опубликован: 22 янв 2016
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаULN2003A
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Delay Time(Typ)250 нс
Drivers Per Package7
Input CompatibilityCMOS,TTL
Iout/ch(Max)500 мА
Iout_off(Typ)50 uA
Output Voltage(Max)50 В
Package GroupSO
Package Size: mm2:W x L16SO: 80 mm2: 7.8 x 10.2(SO) PKG
Peak Output Current500 мА
Switching Voltage(Max)50 В
Vol@Lowest Spec Current(Typ)900 мВ
  • Evaluation Modules & Boards: BOOSTXL-ULN2003
    Dual Stepper Motor Driver BoosterPack featuring ULN2003 and CSD17571Q2 NexFETВ™
  • Development Kits: TIEVM-HV-1PH-DCAC
    Single Phase Inverter Reference Design With Voltage Source and Grid Connected Modes
  • Improved Thermal Dissipation and Energy Efficiency for Peripheral Driving
    PDF, 330 Кб, Файл опубликован: 30 окт 2014
  • Stepper Motor Driving with Peripheral Drivers (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
    This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
  • Semiconductors > Power Management > Peripheral Driver and Actuator
На английском языке: Datasheet Texas Instruments ULN2003ANSRG4
