Datasheet Texas Instruments ULN2003BDR — Даташит
| Серия | ULN2003B |
| Модель | ULN2003BDR |
Высоковольтная сильноточная транзисторная матрица Дарлингтона 16-SOIC -40 до 105
ULN2003B High-Voltage, High-Current Darlington Transistor Array datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 16 авг 2016
Купить ULN2003BDR на РадиоЛоцман.Цены — от 7.40 до 61 ₽26 предложений от 12 поставщиков IC PWR RELAY 7NPN 1:1 16SOIC. Bipolar (BJT) Transistor Array 7 NPN Darlington 50V 500mA Surface Mount 16-SOIC. Transistors - Bipolar... | |||
| ULN2003BDR Texas Instruments | от 7.40 ₽ | ||
| ULN2003BDR Texas Instruments | 54 ₽ | ||
| ULN2003BDR Texas Instruments | от 60 ₽ | ||
| ULN2003BDR Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | ULN2003B |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Delay Time(Typ) | 250 нс |
| Drivers Per Package | 7 |
| Input Compatibility | CMOS,TTL |
| Iout/ch(Max) | 500 мА |
| Iout_off(Typ) | 50 uA |
| Output Voltage(Max) | 50 В |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Peak Output Current | 500 мА |
| Rating | Catalog |
| Switching Voltage(Max) | 50 В |
| Vol@Lowest Spec Current(Typ) | 900 мВ |
- Improved Thermal Dissipation and Energy Efficiency for Peripheral DrivingPDF, 330 Кб, Файл опубликован: 30 окт 2014
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: ULN2003B (3)
- ULN2003BDR ULN2003BN ULN2003BPWR
- Semiconductors > Power Management > Peripheral Driver and Actuator
