Datasheet Texas Instruments ULN2003V12DR — Даташит
Серия | ULN2003V12 |
Модель | ULN2003V12DR |
Драйвер реле малой мощности 7-канальный 16-SOIC -40 до 125
ULN2003V12 7-Channel Relay and Inductive Load Sink Driver datasheet
PDF, 920 Кб, Версия: C, Файл опубликован: 18 ноя 2016
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | U2003V12 |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Delay Time(Typ) | 80 нс |
Drivers Per Package | 7 |
Input Compatibility | CMOS |
Iout/ch(Max) | 140 мА |
Iout_off(Typ) | 0.5 uA |
Output Voltage(Max) | 16 В |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Peak Output Current | 1000 мА |
Rating | Catalog |
Switching Voltage(Max) | 16 В |
Vol@Lowest Spec Current(Typ) | 600 мВ |
- Improved Thermal Dissipation and Energy Efficiency for Peripheral DrivingPDF, 330 Кб, Файл опубликован: 30 окт 2014
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: ULN2003V12 (2)
- ULN2003V12DR ULN2003V12PWR
- Semiconductors > Power Management > Peripheral Driver and Actuator
