Datasheet Texas Instruments ULN2003V12PWR — Даташит
СерияULN2003V12
МодельULN2003V12PWR
Драйвер реле малой мощности 7-канальный 16-TSSOP -40 до 125
ULN2003V12 7-Channel Relay and Inductive Load Sink Driver datasheet
PDF, 920 Кб, Версия: C, Файл опубликован: 18 ноя 2016
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаU2003V12
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Delay Time(Typ)80 нс
Drivers Per Package7
Input CompatibilityCMOS
Iout/ch(Max)140 мА
Iout_off(Typ)0.5 uA
Output Voltage(Max)16 В
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Peak Output Current1000 мА
Switching Voltage(Max)16 В
Vol@Lowest Spec Current(Typ)600 мВ
  • Improved Thermal Dissipation and Energy Efficiency for Peripheral Driving
    PDF, 330 Кб, Файл опубликован: 30 окт 2014
  • Stepper Motor Driving with Peripheral Drivers (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
    This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: ULN2003V12 (2)
  • Semiconductors > Power Management > Peripheral Driver and Actuator
На английском языке: Datasheet Texas Instruments ULN2003V12PWR
