Datasheet Texas Instruments ULQ2003AD — Даташит
| Серия | ULQ2003A |
| Модель | ULQ2003AD |
Транзисторные матрицы Дарлингтона 16-SOIC от -40 до 85
ULN200x, ULQ200x High-Voltage, High-Current Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: O, Файл опубликован: 22 янв 2016
Купить ULQ2003AD на РадиоЛоцман.Цены — от 12 до 338 ₽32 предложений от 18 поставщиков IC PWR DRIVER NPN 1:1 16SOIC. Power Switch/Driver 1:1 NPN 500mA 16-SOIC. PMIC - Power Distribution Switches, Load Drivers | |||
| ULQ2003AD Texas Instruments | 22 ₽ | ||
| ULQ2003AD Texas Instruments | от 28 ₽ | ||
| ULQ2003AD National Semiconductor | 37 ₽ | ||
| ULQ2003AD | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 40 |
| Carrier | TUBE |
| Маркировка | ULQ2003A |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Delay Time(Typ) | 1000 нс |
| Drivers Per Package | 7 |
| Input Compatibility | CMOS,TTL |
| Iout/ch(Max) | 500 мА |
| Iout_off(Typ) | 100 uA |
| Output Voltage(Max) | 50 В |
| Package Group | SOIC |
| Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
| Peak Output Current | 500 мА |
| Rating | Catalog |
| Switching Voltage(Max) | 50 В |
| Vol@Lowest Spec Current(Typ) | 900 мВ |
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: ULQ2003A (5)
- ULQ2003AD ULQ2003ADG4 ULQ2003ADR ULQ2003ADRG4 ULQ2003AN
- Semiconductors > Power Management > Peripheral Driver and Actuator
