Datasheet Texas Instruments ULQ2004AD — Даташит
Серия | ULQ2004A |
Модель | ULQ2004AD |
Высоковольтная, сильноточная транзисторная матрица Дарлингтона 16-SOIC -40 до 85
ULN200x, ULQ200x High-Voltage, High-Current Darlington Transistor Arrays datasheet
PDF, 1.3 Мб, Версия: O, Файл опубликован: 22 янв 2016
![]() 31 предложений от 17 поставщиков Двухполюсный плоскостной транзистор, SOIC NPN 50V 0.5A | |||
ULQ2004AD Texas Instruments | 25 ₽ | ||
ULQ2004AD Texas Instruments | от 52 ₽ | ||
ULQ2004AD | 143 ₽ | ||
ULQ2004AD Texas Instruments | по запросу |
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | ULQ2004A |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Delay Time(Typ) | 1000 нс |
Drivers Per Package | 7 |
Input Compatibility | CMOS |
Iout/ch(Max) | 500 мА |
Iout_off(Typ) | 50 uA |
Output Voltage(Max) | 50 В |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Peak Output Current | 500 мА |
Rating | Catalog |
Switching Voltage(Max) | 50 В |
Vol@Lowest Spec Current(Typ) | 900 мВ |
- Stepper Motor Driving with Peripheral Drivers (Rev. A)PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
Серия: ULQ2004A (5)
- ULQ2004AD ULQ2004ADG4 ULQ2004ADR ULQ2004ADRG4 ULQ2004AN
- Semiconductors > Power Management > Peripheral Driver and Actuator
