Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments VC5501LMPGF300 — Даташит
СерияTMS320VC5501
МодельVC5501LMPGF300
Процессор цифровых сигналов с фиксированной точкой 176-LQFP от -40 до 85
TMS320VC5501 Fixed-Point Digital Signal Processor datasheet
PDF, 2.4 Мб, Версия: K, Файл опубликован: 20 ноя 2008
Pin176176176
Package TypePGFPGFPGF
Industry STD TermLQFPLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-GS-PQFP-G
Package QTY404040
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320VC5501PGF300
Width (мм)242424
Length (мм)242424
Thickness (мм)1.41.41.4
Pitch (мм).5.5.5
Max Height (мм)1.61.61.6
ApplicationsAudio,Automotive,Communications and Telecom,Consumer Electronics,Industrial
DRAMSDRAM
DSP1 C55x
DSP MHz300 Max.
HPI1 8-bit HPI
I2C1
McBSP2
Operating SystemsDSP/BIOS,VLX
UART1 SCI
  • Evaluation Modules & Boards: TMDX5502EZDSP
    C5502 eZdsp Development Kit
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • TMS320VC5501 Hardware Designer's Resource Guide
    PDF, 176 Кб, Файл опубликован: 22 июл 2004
    The DSP Hardware Designer's Resource Guide is organized by development flow and functional areas to make your design effort as seamless as possible. Topics covered include getting started, board design, system testing, and checklists to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, models, symbols, and refere
  • Using the TMS320VC5501/5502 Bootloader (Rev. C)
    PDF, 439 Кб, Версия: C, Файл опубликован: 19 окт 2004
    This document describes the features of the on-chip bootloader provided with the TMS320VC5501 and TMS320VC5502 digital signal processors (DSPs). Included are descriptions of each of the available boot modes and any interfacing requirements associated with them, instructions on generating the boot table, and information on the different versions of the bootloader.This document contains prelimina
  • Achieving Efficient Memory System Performance w/ I-Cache on the TMS320VC5501/02 (Rev. A)
    PDF, 265 Кб, Версия: A, Файл опубликован: 24 июн 2004
    The TMS320VC5501 and TMS320VC5502 were designed as low cost DSPs for low cost real-time solutions. In order to achieve the best performance with these processors the system designer must follow the guidelines provided in the application report.Execute code from external memory with the on-chip I-Cache enabled.Locate data in internal memory at run time.Use the External Memory I
  • TMS320VC5501, TMS320VC5502 Power Consumption Summary (Rev. A)
    PDF, 66 Кб, Версия: A, Файл опубликован: 13 дек 2016
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments VC5501LMPGF300
