Datasheet Texas Instruments WL1801MODGBMOCR — Даташит
СерияWL1801MOD
МодельWL1801MODGBMOCR
Однодиапазонный модуль Wi-Fi® WiLink™ 8 100-QFM -20 до 70
WL18xxMOD WiLink 8 Single-Band Combo Module – Wi-Fi, Bluetooth, and Bluetooth Low Energy (LE) datasheet
PDF, 1.5 Мб, Версия: L, Файл опубликован: 1 дек 2015
Pin100100100100100
Package TypeMOCMOCMOCMOCMOC
Industry STD TermQFMQFMQFMQFMQFM
JEDEC CodeS-PQSI-NS-PQSI-NS-PQSI-NS-PQSI-NS-PQSI-N
Package QTY12001200120012001200
Маркировка201-135370Z64-WL18SBMOD451I-WL18SBMOD01WL18MODGB
Width (мм)13.413.413.413.413.4
Length (мм)13.313.313.313.313.3
Thickness (мм)22222
Pitch (мм).7.7.7.7.7
Max Height (мм)22222
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачать
Device TypeSmart RF Transceiver,Module
Integrated Bluetooth ControllerNo
Key ApplicationsAudio, Home & Building Automation, Internet of Things (IoT), Medical, Smart Grid
Key Wi-Fi Features802.11bgn, AP, STA, Wi-Fi Direct Mode, Mesh over Wi-Fi based on 802.11s
Рабочий диапазон температурот -20 до 70 C
КорпусMOC (100 pin LGA Module) мм
ПериферияSDIO (Wi-Fi)
ProcessorExternal MPU
Supported Wi-Fi Band2.4 GHz
TechnologyWi-Fi
Throughput(Max)100 Mbps
Wi-Fi Idle Connect Current0.8 (DTIM = 1) мА
Wi-Fi RX Sensitivity-96.3 (@ 1 DSSS) dBm
Wi-Fi TX Output Power17.3 (@ 1 DSSS) dBm
  • Evaluation Modules & Boards: TMDXEVM437X
    AM437x Evaluation Module
  • Evaluation Modules & Boards: WL18XXCOM82SDMMC
    WL18XXCOM82SDMMC
  • Evaluation Modules & Boards: TMDSEVM437X
  • Daughter Cards: WL1835MODCOM8B
    WiLinkВ™ 8 Module 2.4 GHz WiFiВ® + BluetoothВ® COM8 Evaluation Module
  • Daughter Cards: WL1837MODCOM8I
    WiLinkВ™ 8 Dual Band 2.4 & 5 GHz Wi-FiВ® + BluetoothВ® COM8 Evaluation Module
  • Evaluation Modules & Boards: BEAGLEBK
    BeagleBone Black Development Board
  • Evaluation Modules & Boards: BEAGLEBN
    BeagleBone Development Board
  • Evaluation Modules & Boards: TMDXEVM3358
    AM335x Evaluation Module
  • Certification Testing Guidelines for WFA System Interoperability Test Plans MCP
    PDF, 2.9 Мб, Файл опубликован: 28 дек 2016
    PDF, 2.9 Мб, Файл опубликован: 15 фев 2016
  • WiLink 8.0TM WLAN IP Mesh Application Report
    PDF, 226 Кб, Файл опубликован: 1 июн 2016
    This application report contains information on the WiLink 8 software mesh solution.
  • WL18xx Level-shifting I/O (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 авг 2015
    WL18xx Level-shifting I/O /HPA/Low-Power_Wireless/2-App_Reports/
  • Precise Time Synchronization Over WLAN (Rev. A)
    PDF, 2.8 Мб, Версия: A, Файл опубликован: 18 дек 2015
    Recently, there has been a big demand for connectivity in the consumer's and industrial's applications. The requirements and implementations are different, but the common denominator is reliability, robustness, performance and scalability, which permits further growth and development according to the industries' progress.The WiFiВ® technology, contrary to the other connectivity solutions
  • WiLink 8 Solutions WiLink8 - wlconf Manual
    PDF, 35 Кб, Файл опубликован: 1 июл 2015
    WiLink 8 Solutions WiLink8 - wlconf Maunal ASPD/Connectivity/WL18xx/App Reports/SWRA489/SWRA489
  • WL18xx .INI File (Rev. A)
    PDF, 134 Кб, Версия: A, Файл опубликован: 3 дек 2015
    WL18xx .INI File /WTBU/WCS/WLAN/UserGuides/SWRU422/SWRU422
  • Certification Testing Guidelines for WFA System Interoperability Test Plans NLCP
Серия: WL1801MOD (2)
  • Semiconductors > Wireless Connectivity > WiLink Combo Solutions
На английском языке: Datasheet Texas Instruments WL1801MODGBMOCR
