Datasheet Texas Instruments WL1837MODGIMOCR — Даташит
СерияWL1837MOD
МодельWL1837MODGIMOCR
WiLink™ 8 промышленный двухдиапазонный, 2x2 MIMO Wi-Fi®, Bluetooth® и Bluetooth Smart модуль 100-QFM -40 до 85
WL18x7MOD WiLink 8 Dual-Band Industrial Module – Wi-Fi, Bluetooth, and Bluetooth Low Energy (LE) datasheet
PDF, 1.6 Мб, Версия: H, Файл опубликован: 12 окт 2015
Pin100100100100100
Package TypeMOCMOCMOCMOCMOC
Industry STD TermQFMQFMQFMQFMQFM
JEDEC CodeS-PQSI-NS-PQSI-NS-PQSI-NS-PQSI-NS-PQSI-N
Package QTY12001200120012001200
CarrierLARGE T&RLARGE T&RLARGE T&RLARGE T&RLARGE T&R
Маркировка451I-WL18DBMOD201-14044737WL18MODGIZ64-WL18DBMOD
Width (мм)13.413.413.413.413.4
Length (мм)13.313.313.313.313.3
Thickness (мм)22222
Pitch (мм).7.7.7.7.7
Max Height (мм)22222
Mechanical DataСкачатьСкачатьСкачатьСкачатьСкачать
Device TypeSmart RF Transceiver, Module
Integrated Bluetooth ControllerYes
Key ApplicationsAudio, Home & Building Automation, Internet of Things (IoT), Medical, Smart Grid
Key Wi-Fi Features802.11abgn, 2x2 MIMO, AP,STA, Wi-Fi Direct Mode, Mesh over Wi-Fi based on 802.11s
КорпусMOC (100 pin LGA Module) мм
ПериферияSDIO (Wi-Fi), UART (Bluetooth)
ProcessorExternal MPU
Supported Wi-Fi Band2.4 GHz,5 GHz
TechnologyBluetooth low energy,Wi-Fi
Throughput(Max)100 Mbps
Wi-Fi Idle Connect Current0.8 (DTIM = 1) мА
Wi-Fi RX Sensitivity-96.3 (@ 1 DSSS) dBm
Wi-Fi TX Output Power17.3 (@ 1 DSSS) dBm
  • Evaluation Modules & Boards: TMDXEVM437X
    AM437x Evaluation Module
  • Evaluation Modules & Boards: WL18XXCOM82SDMMC
    WL18XXCOM82SDMMC
  • Evaluation Modules & Boards: TMDSEVM437X
  • Daughter Cards: WL1835MODCOM8B
    WiLinkВ™ 8 Module 2.4 GHz WiFiВ® + BluetoothВ® COM8 Evaluation Module
  • Daughter Cards: WL1837MODCOM8I
    WiLinkВ™ 8 Dual Band 2.4 & 5 GHz Wi-FiВ® + BluetoothВ® COM8 Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM3358
    AM335x Evaluation Module
  • Evaluation Modules & Boards: TMDSCSK8127
    TMS320DM8127 Camera Starter Kit (CSK)
  • Evaluation Modules & Boards: TMDSCSK388
    DM38x Camera Starter Kit (CSK)
  • WL18xx 5GHZ Antenna Diversity
    PDF, 60 Кб, Файл опубликован: 29 июн 2015
    Realistic wireless channel models consider the impact of multipath propagation. Since a transmitted signal is subject to reflections and refraction on walls, surfaces, and so forth, the receiving node will see signals differing in phase and amplitude. Using more than one antenna allows the evaluation of different multipath scenarios to avoid or reduce the effects of fading and interferences. Diver
  • Enhanced HCILL: Four-Wire Power Management Protocol (Rev. B)
    PDF, 97 Кб, Версия: B, Файл опубликован: 24 сен 2015
  • Secure Connection Capability for WiLink Bluetooth 4.2
    PDF, 64 Кб, Файл опубликован: 19 май 2017
    The WiLinkв„ў 8, Wi-Fiв„ў and BluetoothВ®/Bluetooth low energy combination solution adds new significantBluetooth 4.2 low energy secure connection capability to existing devices. These capabilities arecompatible with the current hardware by downloading the new TI-BT-4-2-STACK-LINUX-ADDON.
  • WL18xx .INI File (Rev. A)
    PDF, 134 Кб, Версия: A, Файл опубликован: 3 дек 2015
    WL18xx .INI File /WTBU/WCS/WLAN/UserGuides/SWRU422/SWRU422
  • WiLink 8 Solutions WiLink8 - wlconf Manual
    PDF, 35 Кб, Файл опубликован: 1 июл 2015
    WiLink 8 Solutions WiLink8 - wlconf Maunal ASPD/Connectivity/WL18xx/App Reports/SWRA489/SWRA489
  • Precise Time Synchronization Over WLAN (Rev. A)
    PDF, 2.8 Мб, Версия: A, Файл опубликован: 18 дек 2015
    Recently, there has been a big demand for connectivity in the consumer's and industrial's applications. The requirements and implementations are different, but the common denominator is reliability, robustness, performance and scalability, which permits further growth and development according to the industries' progress.The WiFiВ® technology, contrary to the other connectivity solutions
  • WL18xx Level-shifting I/O (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 авг 2015
    WL18xx Level-shifting I/O /HPA/Low-Power_Wireless/2-App_Reports/
  • WiLink 8.0TM WLAN IP Mesh Application Report
    PDF, 226 Кб, Файл опубликован: 1 июн 2016
    This application report contains information on the WiLink 8 software mesh solution.
  • Certification Testing Guidelines for WFA System Interoperability Test Plans
    PDF, 2.9 Мб, Файл опубликован: 15 фев 2016
  • Certification Testing Guidelines for WFA System Interoperability Test Plans MCP
    PDF, 2.9 Мб, Файл опубликован: 28 дек 2016
  • Certification Testing Guidelines for WFA System Interoperability Test Plans NLCP
Серия: WL1837MOD (2)
  • Semiconductors > Wireless Connectivity > Wi-Fi > WiLink WL18xx (Wi-Fi+BT/BLE)
На английском языке: Datasheet Texas Instruments WL1837MODGIMOCR
