Datasheet Texas Instruments XTR101AU/1K — Даташит
Серия | XTR101 |
Модель | XTR101AU/1K |
Прецизионный двухпроводной датчик с малым дрейфом, 4–20 мА, 16-SOIC, от -40 до 85
XTR101: Precision, Low Drift 4-20mA Two-Wire Transmitter datasheet
PDF, 788 Кб, Версия: A, Файл опубликован: 3 авг 2004
![]() 17 предложений от 13 поставщиков Микросхема Операционный усилитель, IC 4-20mA TRANSMITTER 16-SOIC | |||
XTR101AU/1K Texas Instruments | 335 ₽ | ||
XTR101AU/1K Texas Instruments | от 1 162 ₽ | ||
XTR101AU/1K Texas Instruments | по запросу | ||
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | XTR101AU |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Full Scale Input Range | 0 to 1V |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Rating | Catalog |
Sub-Family | 4-20mA Transmitter |
Vs(Max) | 40 В |
Vs(Min) | 11.6 В |
- Evaluation Modules & Boards: DLPNIRSCANEVM
DLPВ® NIRscanВ™ Evaluation Module
- 20mA to 0-20mA Converter & Current Summing Current-to-Current ConvertersPDF, 57 Кб, Файл опубликован: 2 окт 2000
Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers. - IC Building Blocks Form Complete Isolated 4-20mA Current-LoopPDF, 72 Кб, Файл опубликован: 27 сен 2000
Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Adding isolation to the 4-20mA current loop protects system electronics from electrical noise and transients. It also allows transducers to be electrically separated by hundreds of volts. - Isolation Amps Hike Accuracy and ReliabilityPDF, 94 Кб, Файл опубликован: 2 окт 2000
Fault tolerance, transient protection, and interference rejection are valuable features that isolation amplifiers bring to critical circuitry. Two useful examples of how designers can employ isolation amplifiers to improve their systems? performance and reliability are process temperature controllers and electrocardiogram (ECG) amplifiers. - Use Low-Impedance Bridges on 4-20mA Current LoopPDF, 27 Кб, Файл опубликован: 27 сен 2000
If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no - Implementation and Applications of Current Sources and Current ReceiversPDF, 427 Кб, Файл опубликован: 27 сен 2000
This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
Серия: XTR101 (8)
- XTR101AG XTR101AP XTR101APG4 XTR101AU XTR101AU/1K XTR101AU/1KG4 XTR101AUG4 XTR101BG
- Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
