Datasheet Texas Instruments XTR101AU/1KG4 — Даташит
СерияXTR101
МодельXTR101AU/1KG4
Прецизионный двухпроводной датчик с малым дрейфом, 4–20 мА, 16-SOIC, от -40 до 85
XTR101: Precision, Low Drift 4-20mA Two-Wire Transmitter datasheet
PDF, 788 Кб, Версия: A, Файл опубликован: 3 авг 2004
Микросхема Буферный усилитель, IC 4-20mA TRANSMITTER 16-SOIC
XTR101AU/1KG4
944 ₽
XTR101AU/1KG4
1 039 ₽
XTR101AU/1KG4
1 069 ₽
LifeElectronics
XTR101AU/1KG4
Pin16
Package TypeDW
Package QTY1000
МаркировкаXTR101AU
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Full Scale Input Range0 to 1V
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Sub-Family4-20mA Transmitter
Vs(Max)40 В
Vs(Min)11.6 В
  • Evaluation Modules & Boards: DLPNIRSCANEVM
    DLPВ® NIRscanВ™ Evaluation Module
  • 20mA to 0-20mA Converter & Current Summing Current-to-Current Converters
    PDF, 57 Кб, Файл опубликован: 2 окт 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers.
  • IC Building Blocks Form Complete Isolated 4-20mA Current-Loop
    PDF, 72 Кб, Файл опубликован: 27 сен 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Adding isolation to the 4-20mA current loop protects system electronics from electrical noise and transients. It also allows transducers to be electrically separated by hundreds of volts.
  • Isolation Amps Hike Accuracy and Reliability
    PDF, 94 Кб, Файл опубликован: 2 окт 2000
    Fault tolerance, transient protection, and interference rejection are valuable features that isolation amplifiers bring to critical circuitry. Two useful examples of how designers can employ isolation amplifiers to improve their systems? performance and reliability are process temperature controllers and electrocardiogram (ECG) amplifiers.
  • Use Low-Impedance Bridges on 4-20mA Current Loop
    PDF, 27 Кб, Файл опубликован: 27 сен 2000
    If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
Серия: XTR101 (8)
  • Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
На английском языке: Datasheet Texas Instruments XTR101AU/1KG4
