Datasheet Texas Instruments XTR105UA/2K5 — Даташит
Серия | XTR105 |
Модель | XTR105UA/2K5 |
Датчик тока 4–20 мА с возбуждением и линеаризацией датчика 14-SOIC от -40 до 85
XTR105: 4-20mA Current Transmitter with Sensor Excitation and Linearization datasheet
PDF, 799 Кб, Версия: B, Файл опубликован: 27 авг 2004
Pin | 14 | 14 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | A | XTR105U |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 8.65 | 8.65 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Full Scale Input Range | 5mV to 1V |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Sub-Family | 4-20mA Transmitter |
Vs(Max) | 36 В |
Vs(Min) | 7.5 В |
- Evaluation Modules & Boards: DLPNIRSCANEVM
DLPВ® NIRscanВ™ Evaluation Module
- 4Q 2011 Issue Analog Applications JournalPDF, 943 Кб, Файл опубликован: 9 ноя 2011
- FOUR-WIRE RTD CURRENT-LOOP TRANSMITTERPDF, 54 Кб, Файл опубликован: 27 сен 2000
Platinum Resistance Temperature Detectors (RTD)s are favored for demanding temperature measurement applications, such as process control, because of their excellent accuracy and sensor interchangeability. Combining an RTD with a Burr-Brown XTR105 forms a complete precision temperature to 4-to-20mA current-loop transmitter solution. Current-mode transmission gives superior noise rejection and is im - 20mA to 0-20mA Converter & Current Summing Current-to-Current ConvertersPDF, 57 Кб, Файл опубликован: 2 окт 2000
Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers. - IC Building Blocks Form Complete Isolated 4-20mA Current-LoopPDF, 72 Кб, Файл опубликован: 27 сен 2000
Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Adding isolation to the 4-20mA current loop protects system electronics from electrical noise and transients. It also allows transducers to be electrically separated by hundreds of volts. - Analog linearization of resistance temperature detectorsPDF, 152 Кб, Файл опубликован: 9 ноя 2011
Серия: XTR105 (9)
- XTR105P XTR105PA XTR105PAG4 XTR105PG4 XTR105U XTR105UA XTR105UA/2K5 XTR105UAG4 XTR105UG4
- Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
