Datasheet Texas Instruments XTR110KU/1K — Даташит
СерияXTR110
МодельXTR110KU/1K
Прецизионный преобразователь напряжения в ток/передатчик 16-SOIC от -40 до 85
Precision Voltage-To-Current Converter/Transmitter datasheet
PDF, 800 Кб, Версия: C, Файл опубликован: 11 сен 2009
Pin16
Package TypeDW
Package QTY1000
МаркировкаXTR110KU
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Full Scale Input Range0 to 10V
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Sub-Family4-20mA Transmitter
Vs(Max)40 В
Vs(Min)13.5 В
  • Evaluation Modules & Boards: DLPNIRSCANEVM
    DLPВ® NIRscanВ™ Evaluation Module
  • Implementing a 4 mA to 20 mA Current Loop on TI DSPs
    PDF, 204 Кб, Файл опубликован: 5 янв 2004
    Use of 4-mA to 20-mA (4-20 mA) current loops has become the standard in the process-control industry due to their increased resistance to noise compared to voltage-modulated signals. TI digital signal processors (DSPs) increasingly are becoming the standard for microcontrollers in a control application. Therefore, an opportunity exists to connect the many sensors and electromechanical devices on t
  • 20mA to 0-20mA Converter & Current Summing Current-to-Current Converters
    PDF, 57 Кб, Файл опубликован: 2 окт 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers.
  • Use Low-Impedance Bridges on 4-20mA Current Loop
    PDF, 27 Кб, Файл опубликован: 27 сен 2000
    If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
  • Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
На английском языке: Datasheet Texas Instruments XTR110KU/1K
