Datasheet Linear Technology LT1005 — Даташит
СерияLT1005
Регулятор с логическим управлением
LT1005 - Logic Controlled Regulator
PDF, 1.1 Мб, Файл закачен: 24 мар 2018
20 предложений от 17 поставщиков
Чип стабилизации напряжения, IC REG LDO 5V 1A/0.035A TO220-5
Элитан
LT1005MK/883
967 ₽
LT1005MK/883
1 069 ₽
LT1005MK
от 2 104 ₽
LT1005-S
  • Circuit Techniques for Clock Sources &mdash AN12
    PDF, 150 Кб, Файл опубликован: 1 окт 1985
    Circuits for clock sources are presented. Special attention is given to crystal-based designs including TXCOs and VXCOs.
  • Performance Enhancement Techniques for Three-Terminal Regulators &mdash AN2
    PDF, 975 Кб, Файл опубликован: 2 авг 1984
    This application note describes a number of enhancement circuit techniques used with existing 3-terminal regulators which extend current capability, limit power dissipation, provide high voltage output, operate from 110VAC or 220VAC without the need to switch transformer windings, and many other usefu application ideas.
  • Micropower Circuits for Signal Conditioning &mdash AN23
    PDF, 2.2 Мб, Файл опубликован: 1 апр 1987
    Low power operation of electronic apparatus has become increasingly desirable. AN23 describes a variety of low power circuits for transducer signal conditioning. Also included are designs for data converters and switching regulators. Three appended sections discuss guidelines for micropower design, strobed power operation and effects of test equipment on micropower circuits.
  • Understanding and Applying the LT1005 Multifunction Regulator &mdash AN1
    PDF, 307 Кб, Файл опубликован: 1 авг 1984
    This application note describes the unique operating characteristics of the LT1005 and describes a number of useful applications which take advantage of the regulator's ability to control the output with a logic control signal.
  • Power Management > LDO Linear Regulators > Positive Linear Regulators (LDO)
На английском языке: Datasheet Linear Technology LT1005
