Оптопары и оптореле Megawin
Datasheet Texas Instruments VFC320BG — Даташит
СерияVFC320
МодельVFC320BG
Преобразователь напряжение-частота и частота-напряжение 14-CDIP
VFC320: Voltage-to-Frequency and Frequency-to-Voltage Converter datasheet
PDF, 228 Кб, Версия: A, Файл опубликован: 13 авг 2001
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Approx. Price (US$)15.82 | 1ku
Operating Temperature Range(C)-25 to 85
Package GroupPDIP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
See datasheet (PDIP)
Vs(Max)(V)20
Vs(Min)(V)13
RoHSНе совместим
  • Frequency-To-Voltage Conversion
    PDF, 106 Кб, Файл опубликован: 27 сен 2000
    This bulletin describes three techniques for making a precision FVC using a VFC. The standard technique has high precision but high ripple or slow settling. Adding an output filter can improve the settling-time ripple trade-off but adds error. A third new technique can eliminate ripple from the FVC output and improve settling time by more than 1000/1 as compared to the conventional FVC. Moreove
  • Voltage-to-Frequency Converters Offer Useful Options in A/D Conversion
    PDF, 48 Кб, Файл опубликован: 2 окт 2000
    Voltage-to-frequency converters (VFCs) provide unique characteristics when used as analog-to-digital (A/D) converters. Their excellent accuracy linearity and integrating input characteristics often provide performance attributes unattainable with other converter types. By using efficient frequency counting techniques familiar speed/accuracy tradeoffs can be averted.
  • Semiconductors > Amplifiers > Special Function Amplifiers > Frequency Converters
На английском языке: Datasheet Texas Instruments VFC320BG
