Datasheet Texas Instruments XTR105PA — Даташит
СерияXTR105
МодельXTR105PA
Датчик тока 4–20 мА с возбуждением и линеаризацией датчика 14-PDIP от -40 до 85
XTR105: 4-20mA Current Transmitter with Sensor Excitation and Linearization datasheet
PDF, 799 Кб, Версия: B, Файл опубликован: 27 авг 2004
Pin1414
Package TypeNN
Industry STD TermPDIPPDIP
JEDEC CodeR-PDIP-TR-PDIP-T
Package QTY2525
CarrierTUBETUBE
МаркировкаXTR105PA
Width (мм)6.356.35
Length (мм)19.319.3
Thickness (мм)3.93.9
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Full Scale Input Range5mV to 1V
Package GroupPDIP
Sub-Family4-20mA Transmitter
Vs(Max)36 В
Vs(Min)7.5 В
  • Evaluation Modules & Boards: DLPNIRSCANEVM
    DLPВ® NIRscanВ™ Evaluation Module
  • FOUR-WIRE RTD CURRENT-LOOP TRANSMITTER
    PDF, 54 Кб, Файл опубликован: 27 сен 2000
    Platinum Resistance Temperature Detectors (RTD)s are favored for demanding temperature measurement applications, such as process control, because of their excellent accuracy and sensor interchangeability. Combining an RTD with a Burr-Brown XTR105 forms a complete precision temperature to 4-to-20mA current-loop transmitter solution. Current-mode transmission gives superior noise rejection and is im
  • IC Building Blocks Form Complete Isolated 4-20mA Current-Loop
    PDF, 72 Кб, Файл опубликован: 27 сен 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Adding isolation to the 4-20mA current loop protects system electronics from electrical noise and transients. It also allows transducers to be electrically separated by hundreds of volts.
  • 20mA to 0-20mA Converter & Current Summing Current-to-Current Converters
    PDF, 57 Кб, Файл опубликован: 2 окт 2000
    Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers.
  • Analog linearization of resistance temperature detectors
    PDF, 152 Кб, Файл опубликован: 9 ноя 2011
  • 4Q 2011 Issue Analog Applications Journal
    PDF, 943 Кб, Файл опубликован: 9 ноя 2011
  • Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
На английском языке: Datasheet Texas Instruments XTR105PA
