Datasheet Texas Instruments XTR110BG — Даташит
Серия | XTR110 |
Модель | XTR110BG |
Прецизионный преобразователь/передатчик напряжения в ток 16-CDIP SB от -40 до 85
Precision Voltage-To-Current Converter/Transmitter datasheet
PDF, 800 Кб, Версия: C, Файл опубликован: 11 сен 2009
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 16 |
Package Type | JD |
Industry STD Term | CDIP SB |
JEDEC Code | R-CDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | XTR110BG |
Width (мм) | 7.37 |
Length (мм) | 20.57 |
Thickness (мм) | 3.5 |
Pitch (мм) | 2.54 |
Max Height (мм) | 4.45 |
Mechanical Data | Скачать |
Full Scale Input Range | 0 to 10V |
Package Group | PDIP,SOIC |
Package Size: mm2:W x L | See datasheet (PDIP),16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Rating | Catalog |
Sub-Family | 4-20mA Transmitter |
Vs(Max) | 40 В |
Vs(Min) | 13.5 В |
- Evaluation Modules & Boards: DLPNIRSCANEVM
DLPВ® NIRscanВ™ Evaluation Module
- Implementing a 4 mA to 20 mA Current Loop on TI DSPsPDF, 204 Кб, Файл опубликован: 5 янв 2004
Use of 4-mA to 20-mA (4-20 mA) current loops has become the standard in the process-control industry due to their increased resistance to noise compared to voltage-modulated signals. TI digital signal processors (DSPs) increasingly are becoming the standard for microcontrollers in a control application. Therefore, an opportunity exists to connect the many sensors and electromechanical devices on t - Use Low-Impedance Bridges on 4-20mA Current LoopPDF, 27 Кб, Файл опубликован: 27 сен 2000
If you need more transducer excitation current than is available on a standard 4-20mA 2-wire current loop, consider a 3-wire transmitter. A 2-wire 4-20mA transmitter uses the same two wires for signal and power. Part of the 4mA minimum loop current is used to power the transmitter circuitry. The remaining current can be used for transducer excitation. In some applications even the entire 4mA is no - 20mA to 0-20mA Converter & Current Summing Current-to-Current ConvertersPDF, 57 Кб, Файл опубликован: 2 окт 2000
Current loops have become the standard for signal transmission in the process control industry. Current loops are insensitive to noise and are immune to errors from line impedance. Burr-Brown offers a complete line of monolithic 4mA to 20mA current loop transmitters and receivers. - Implementation and Applications of Current Sources and Current ReceiversPDF, 427 Кб, Файл опубликован: 27 сен 2000
This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
Серия: XTR110 (8)
- Semiconductors > Sensing Products > Application-Specific Sensor Signal Conditioners
