Datasheet Texas Instruments MPC102AU — Даташит
СерияMPC102
МодельMPC102AU
Широкополосный двойной видеомультиплексор 2 x 1 14-SOIC от -40 до 85
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Multiplexer Data Acquisition System
    PDF, 71 Кб, Файл опубликован: 4 окт 2000
    Multiplexers have been used for acquisition of quasi-static signals for a long time. While these signals usually have a low bandwidth of only a few hertz, applications generally require that the multiplexer send each signal as fast as possible to the converter and that the signals be processed quickly. To ensure fast processing, such acquisition systems usually include a sense amplifier behind the
Серия: MPC102 (1)
  • MPC102AU
  • Semiconductors > Switches and Multiplexers > Multiplexer/Demultiplexer (Mux/Demux) > Analog Mux/Demux
На английском языке: Datasheet Texas Instruments MPC102AU
