Datasheet Texas Instruments MPC509AU — Даташит
СерияMPC509
МодельMPC509AU
4-канальный аналоговый мультиплексор с дифференциальным входом, 16-SOIC
MPC508, MPC509: Single-Ended 8-Chan/Differential 4-Chan CMOS Analog Multiplexers datasheet
PDF, 976 Кб, Версия: A, Файл опубликован: 17 сен 2003
Pin16
Package TypeDW
Package QTY40
МаркировкаMPC509AU
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Additional FeaturesDual supply,Powered off protection,Overvoltage Protection,Break-before-make
Configuration4:1
Input/Ouput Voltage(Max)15 В
Input/Ouput Voltage(Min)-15 В
Input/Output Continuous Current(Max)20 мА
Input/Output OFF-state Capacitance(Typ)5 пФ
Количество каналов2
OFF-state leakage current(Max)0.01 мкА
ON-state leakage current(Max)0.01 мкА
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Ron(Max)1800 Ohms
Ron(Typ)1300 Ohms
Supply Current(Max)1500 uA
Supply Current(Typ)700 uA
Supply Range15 Max
VIH(Min)4 В
VIL(Max)0.8 В
Vdd(Max)15 В
Vdd(Min)5 В
Vss(Max)-5 В
Vss(Min)-15 В
  • Multiplexer Data Acquisition System
    PDF, 71 Кб, Файл опубликован: 4 окт 2000
    Multiplexers have been used for acquisition of quasi-static signals for a long time. While these signals usually have a low bandwidth of only a few hertz, applications generally require that the multiplexer send each signal as fast as possible to the converter and that the signals be processed quickly. To ensure fast processing, such acquisition systems usually include a sense amplifier behind the
На английском языке: Datasheet Texas Instruments MPC509AU
