Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS65010RGZR — Даташит
СерияTPS65010
МодельTPS65010RGZR
Многоканальное 1-элементное литий-ионное зарядное устройство PMIC USB/AC, 2 постоянного/постоянного тока, 2 LDO, интерфейс I2C в QFN-48 48-VQFN от -40 до 85
TPS65010 Power and Battery Management IC for Li-Ion Powered Systems datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 30 сен 2015
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаTPS65010
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Iout(Max)1 A
Iq(Typ)0.07 мА
LDO2
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Regulated Outputs4
Special FeaturesPower Good
Step-Down DC/DC Converter2
Switching Frequency(Max)1500 kHz
Vin(Max)6.5 В
Vin(Min)1.8 В
Vout(Max)6.5 В
Vout(Min)0.85 В
  • Evaluation Modules & Boards: TPS65010EVM-230
    TPS65010 Evaluation Module
  • Evaluation Modules & Boards: TPS65011EVM-049
    TPS65011 Evaluation Module
  • TPS6501x Device Comparison (Rev. B)
    PDF, 68 Кб, Версия: B, Файл опубликован: 12 июл 2005
    This application report presents an overview on the differences among the TPS6501x family members. Devices included are the TPS65010, TPS65011, TPS65012,TPS65013, and TPS65014. It is intended to assist design engineers in selecting the most suitable device for their applications.
  • OMAP5910 Low-Power System Design (Rev. A)
    PDF, 309 Кб, Версия: A, Файл опубликован: 25 мар 2004
    The OMAP5910 is a true system-on-a-chip device, which consists of ARM925T MPU and C55X DSP cores. The device has many advanced power management modes that enable system designers to develop a very low-power, multimedia communication device. This application note shows low-power design techniques and outlines the steps required to put the OMAPв„ў device in the lowest power consumption mode and
  • Understanding the TPS65010 Software
    PDF, 548 Кб, Файл опубликован: 17 ноя 2003
    The TPS65010 is an integrated, extremely versatile IC. It contains a Li-Ion battery charger,two switching regulators, two linear regulators, two LED drivers, a motor driver, 4 GPIOs, and an assortment of control and status bits. All outputs are configurable by an external processor via an I2C bus. The TPS65010 contains sixteen 8-bit registers that both control the functions of the IC as well as re
  • Selecting the correct IC for power-supply applications
    PDF, 184 Кб, Файл опубликован: 14 дек 2006
  • Optimizing Resistor Dividers at a Comparator (Rev. A)
    PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65010 (4)
  • Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
На английском языке: Datasheet Texas Instruments TPS65010RGZR
