Datasheet Linear Technology LT3755-1 — Даташит
СерияLT3755-1
Контроллеры светодиодов 40VIN, 75VOUT
LT3755/LT3755-1/LT3755-2 - 40VIN, 75VOUT LED Controllers
PDF, 359 Кб, Версия: D, Файл закачен: 4 окт 2017
5 предложений от 5 поставщиков
32-Channel 20mA LED Driver with Buck Controller 0.5??s Minimum LED On Time
МосЧип
LT3755-1
LT37551
ЗУМ-СМД
LT37551
LT37551
LT3755EMSE-1#PBFLT3755EMSE-1#TRPBFLT3755EUD-1#PBFLT3755EUD-1#TRPBFLT3755IMSE-1#PBFLT3755IMSE-1#TRPBFLT3755IUD-1#PBFLT3755IUD-1#TRPBF
N12345678
КорпусMS-16E
Габаритный чертеж корпуса
MS-16E
3x3 QFN-16
3x3 QFN-16
MS-16E
MS-16E
3x3 QFN-16
3x3 QFN-16
Код корпусаMSEMSEUDUDMSEMSEUDUD
Индекс корпуса05-08-166705-08-166705-08-169105-08-169105-08-166705-08-166705-08-169105-08-1691
Количество выводов1616161616161616
Parameters / ModelsLT3755EMSE-1#PBFLT3755EMSE-1#TRPBFLT3755EUD-1#PBFLT3755EUD-1#TRPBFLT3755IMSE-1#PBFLT3755IMSE-1#TRPBFLT3755IUD-1#PBFLT3755IUD-1#TRPBF
АрхитектураImproved Average Output Current ControlImproved Average Output Current ControlImproved Average Output Current ControlImproved Average Output Current ControlImproved Average Output Current ControlImproved Average Output Current ControlImproved Average Output Current ControlImproved Average Output Current Control
Demo BoardsDC1268B-A,DC1268B-BDC1268B-A,DC1268B-BDC1268B-A,DC1268B-BDC1268B-A,DC1268B-BDC1268B-A,DC1268B-BDC1268B-A,DC1268B-BDC1268B-A,DC1268B-BDC1268B-A,DC1268B-B
Design ToolsLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice FileLTspice File
Dimming3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog3000:1 PWM, 10:1 Analog
Экспортный контрольнетнетнетнетнетнетнетнет
Основные особенностиTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External SynchronizationTrue Color PWM Dimming, Open LED Detection, Resistor Set Frequency, External Synchronization
Тактовая частота, kHz10001000100010001000100010001000
Ishutdown, мкА.1.1.1.1.1.1.1.1
Isupply, мА1.41.41.41.41.41.41.41.4
Max Number of LEDs25+25+25+25+25+25+25+25+
Monolithicнетнетнетнетнетнетнетнет
Количество выходов11111111
Рабочий диапазон температур, °Cот 0 до 85от 0 до 85от 0 до 85от 0 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Выходной ток, A1010101010101010
Switch Current, A2525252525252525
Synchronousнетнетнетнетнетнетнетнет
TopologyBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED DriverBuck, Boost, Sepic, Buck-Boost, LED Driver
Vin Max, В4040404040404040
Vin Min, В4.54.54.54.54.54.54.54.5
Vout Max, В7575757575757575
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT3755 LT3755-2
Статьи
  • Don't Want to Hear It? Avoid the Audio Band with PWM LED Dimming at Frequencies Above 20kHz &mdash LT Journal
    PDF, 596 Кб, Файл опубликован: 1 мар 2009
  • Power Management > LED Driver ICs > Step-Up (Boost) LED Drivers | Step-Down (Buck) LED Drivers | Buck-Boost LED Drivers | Multitopology LED Driver
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) LED Drivers
На английском языке: Datasheet Linear Technology LT3755-1
