Datasheet ТI CC1312R1F3RGZR — Даташит
СерияCC1312R
МодельCC1312R1F3RGZR
Datasheet Texas Instruments CC1312R1F3RGZR
SimpeLink Sub-1 GHz CC1312R беспроводной микроконтроллер 48-VQFN -40 to 85
CC1312R SimpleLink High-Performance Sub-1 GHz Wireless MCU datasheet
PDF, 547 Кб, Файл опубликован: 16 янв 2018
  • Low-Power ADC Solution for CC13x2 and CC26x2
    PDF, 190 Кб, Файл опубликован: 2 мар 2018
    The 12-bit analog-to-digital converter (ADC) peripheral block included in CC13x2 and CC26x2 deviceswhich is typically used by the Sensor Controller requires the SCLK_HF signal and is therefore notavailable in low-power (2 MHz) mode. The goal of this application note is to help users create an 8-bitsuccessive-approximation (SAR)-type low-power ADC using the CC13x2 and CC26x2 Sensor Con
  • Single-Chip Flow Metering Solution With the CC13x2R Wireless MCUs
    PDF, 88 Кб, Файл опубликован: 27 фев 2018
  • Sensor Sequencing Using the CC13x2 and CC26x2 Sensor Controller
    PDF, 252 Кб, Файл опубликован: 5 мар 2017
    The purpose of this application note is to demonstrate how current consumption can be minimized bymaking the Sensor Controller automatically enable a sensor at a designated time period before the sensoris to be sampled. This implementation allows the Sensor Controller to stay in the lowest-possible powermode while the sensor boots and then start up when the sensor is ready. In this appl
  • Hardware Migration From CC1310 to CC1312R
    PDF, 27 Кб, Файл опубликован: 17 окт 2017
    This application report describes the required hardware changes when moving from the CC1310 to the CC1312R SimpleLin™ wireless MCU.
  • Ultra-Low Power Designs With the CC13x2 and CC26x2 Sensor Controller
    PDF, 87 Кб, Файл опубликован: 27 фев 2018
  • Getting Started With the CC13xx and CC26xx Sensor Controller
    PDF, 1.1 Мб, Файл опубликован: 6 окт 2017
    This application note is intended as an introduction to the low-power Sensor Controller Engine found in theCC13xx and CC26xx devices. It explains the benefits of using the Sensor Controller in various use cases.The application note also describes how to get started using the Sensor Controller and directs you to therequired tools and collaterals.
Серия: CC1312R (3)
  • Semiconductors > Wireless Connectivity > SimpleLink Solutions > Sub-1 GHz
На английском языке: Datasheet Texas Instruments CC1312R1F3RGZR
Политика конфиденциальности
