Datasheet Texas Instruments XCC1352R1F3RGZR — Даташит
СерияCC1352R
МодельXCC1352R1F3RGZR
SimpleLink Многодиапазонный беспроводной микроконтроллер CC1352R 48-VQFN -40 до 85
CC1352R SimpleLink High-Performance Dual-Band Wireless MCU datasheet
PDF, 1.1 Мб, Файл опубликован: 16 янв 2018
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)7
Length (мм)7
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
Bluetooth StandardSPI,UART,I2S,I2C
Data Rate(Max)5000 kbps
Device TypeSimpleLink Wireless MCU
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Security EnablerCryptographic acceleration,Debug security,Device identity,Software IP protection
TechnologySub-1 GHz,Bluetooth low energy,Zigbee,Thread
Throughput(Max)5 Mbps
  • Debug Probes/Analyzers: TMDSEMU200-U
    XDS200 USB Debug Probe
  • Development Kits: LAUNCHXL-CC1352R1
    SimpleLink Multi-Band CC1352R Wireless MCU LaunchPad Development Kit
  • Low-Power ADC Solution for CC13x2 and CC26x2
    PDF, 190 Кб, Файл опубликован: 2 мар 2018
    The 12-bit analog-to-digital converter (ADC) peripheral block included in CC13x2 and CC26x2 deviceswhich is typically used by the Sensor Controller requires the SCLK_HF signal and is therefore notavailable in low-power (2 MHz) mode. The goal of this application note is to help users create an 8-bitsuccessive-approximation (SAR)-type low-power ADC using the CC13x2 and CC26x2 Sensor Con
  • Use of Low-power ZigbeeВ® and Thread With the SimpleLinkв„ў Wireless MCU Family
    PDF, 81 Кб, Файл опубликован: 27 фев 2018
  • Single-Chip Flow Metering Solution With the CC13x2R Wireless MCUs
    PDF, 88 Кб, Файл опубликован: 27 фев 2018
  • Sensor Sequencing Using the CC13x2 and CC26x2 Sensor Controller
    PDF, 252 Кб, Файл опубликован: 5 мар 2017
    The purpose of this application note is to demonstrate how current consumption can be minimized bymaking the Sensor Controller automatically enable a sensor at a designated time period before the sensoris to be sampled. This implementation allows the Sensor Controller to stay in the lowest-possible powermode while the sensor boots and then start up when the sensor is ready. In this appl
  • Ultra-Low Power Designs With the CC13x2 and CC26x2 Sensor Controller
    PDF, 87 Кб, Файл опубликован: 27 фев 2018
  • Getting Started With the CC13xx and CC26xx Sensor Controller
    PDF, 1.1 Мб, Файл опубликован: 6 окт 2017
    This application note is intended as an introduction to the low-power Sensor Controller Engine found in theCC13xx and CC26xx devices. It explains the benefits of using the Sensor Controller in various use cases.The application note also describes how to get started using the Sensor Controller and directs you to therequired tools and collaterals.
Серия: CC1352R (3)
  • Semiconductors > Wireless Connectivity > SimpleLink Solutions > Multi-Standard
На английском языке: Datasheet Texas Instruments XCC1352R1F3RGZR
