Линейка продуктов KEEN SIDE
Datasheet Texas Instruments CC1352R — Даташит
СерияCC1352R
Многодиапазонный беспроводной микроконтроллер SimpleLink CC1352R
CC1352R SimpleLink High-Performance Dual-Band Wireless MCU datasheet
PDF, 1.1 Мб, Файл опубликован: 16 янв 2018
CC1352R1F3RGZRCC1352R1F3RGZTXCC1352R1F3RGZR
Статус продуктаАнонсированАнонсированВ производстве
Доступность образцов у производителяНетНетДа
N123
Pin484848
Package TypeRGZRGZRGZ
Industry STD TermVQFNVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-NS-PQFP-N
Package QTY25002502500
CarrierLARGE T&RSMALL T&RLARGE T&R
Width (мм)777
Length (мм)777
Thickness (мм)0.90.90.9
Pitch (мм)0.50.50.5
Max Height (мм)111
Parameters / ModelsCC1352R1F3RGZR
CC1352R1F3RGZR
CC1352R1F3RGZT
CC1352R1F3RGZT
XCC1352R1F3RGZR
XCC1352R1F3RGZR
Bluetooth StandardSPI,UART,I2S,I2CSPI,UART,I2S,I2CSPI,UART,I2S,I2C
Data Rate(Max), kbps500050005000
Device TypeSimpleLink Wireless MCUSimpleLink Wireless MCUSimpleLink Wireless MCU
Package GroupVQFNVQFNVQFN
Package Size: mm2:W x L, PKG48VQFN: 49 mm2: 7 x 7(VQFN)48VQFN: 49 mm2: 7 x 7(VQFN)48VQFN: 49 mm2: 7 x 7(VQFN)
RatingCatalogCatalogCatalog
Security EnablerCryptographic acceleration,Debug security,Device identity,Software IP protectionCryptographic acceleration,Debug security,Device identity,Software IP protectionCryptographic acceleration,Debug security,Device identity,Software IP protection
TechnologySub-1 GHz,Bluetooth low energy,Zigbee,ThreadSub-1 GHz,Bluetooth low energy,Zigbee,ThreadSub-1 GHz,Bluetooth low energy,Zigbee,Thread
Throughput(Max), Mbps555
RoHSSee ti.comSee ti.comСовместим
  • Low-Power ADC Solution for CC13x2 and CC26x2
    PDF, 190 Кб, Файл опубликован: 2 мар 2018
    The 12-bit analog-to-digital converter (ADC) peripheral block included in CC13x2 and CC26x2 deviceswhich is typically used by the Sensor Controller requires the SCLK_HF signal and is therefore notavailable in low-power (2 MHz) mode. The goal of this application note is to help users create an 8-bitsuccessive-approximation (SAR)-type low-power ADC using the CC13x2 and CC26x2 Sensor Con
  • Use of Low-power ZigbeeВ® and Thread With the SimpleLinkв„ў Wireless MCU Family
    PDF, 81 Кб, Файл опубликован: 27 фев 2018
  • Single-Chip Flow Metering Solution With the CC13x2R Wireless MCUs
    PDF, 88 Кб, Файл опубликован: 27 фев 2018
  • Sensor Sequencing Using the CC13x2 and CC26x2 Sensor Controller
    PDF, 252 Кб, Файл опубликован: 5 мар 2017
    The purpose of this application note is to demonstrate how current consumption can be minimized bymaking the Sensor Controller automatically enable a sensor at a designated time period before the sensoris to be sampled. This implementation allows the Sensor Controller to stay in the lowest-possible powermode while the sensor boots and then start up when the sensor is ready. In this appl
  • Ultra-Low Power Designs With the CC13x2 and CC26x2 Sensor Controller
    PDF, 87 Кб, Файл опубликован: 27 фев 2018
  • Getting Started With the CC13xx and CC26xx Sensor Controller
    PDF, 1.1 Мб, Файл опубликован: 6 окт 2017
    This application note is intended as an introduction to the low-power Sensor Controller Engine found in theCC13xx and CC26xx devices. It explains the benefits of using the Sensor Controller in various use cases.The application note also describes how to get started using the Sensor Controller and directs you to therequired tools and collaterals.
  • Semiconductors > Wireless Connectivity > SimpleLink Solutions > Multi-Standard
На английском языке: Datasheet Texas Instruments CC1352R
