Datasheet Texas Instruments CC2652R1FRGZT — Даташит
СерияCC2652R
МодельCC2652R1FRGZT
SimpleLink Multi-Standard CC2652R беспроводной микроконтроллер 48-VQFN -40 до 85
CC2652R SimpleLink Multiprotocol 2.4-GHz Wireless MCU datasheet
PDF, 480 Кб, Файл опубликован: 16 янв 2018
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Width (мм)7
Length (мм)7
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
ADC1
Data Rate(Max)5000 kbps
Device TypeSimpleLink Wireless MCU
Flash352 KB
GPIO31
Key ApplicationsHome & Building Automation,Smart Grid
Выходная мощность5 dBm
Package GroupVQFN
RX Current (Lowest)6.5 мА
TechnologyBluetooth,Zigbee,Thread,Proprietary 2.4 GHz
Throughput(Max)5 Mbps
Timers - 16-bit8
Timers - 32-bit4
RoHSSee ti.com
  • Evaluation Modules & Boards: LAUNCHXL-CC26X2R1
    SimpleLink Multi-Standard CC26x2R Wireless MCU LaunchPad Development Kit
  • Debug Probes/Analyzers: TMDSEMU200-U
    XDS200 USB Debug Probe
  • Use of Low-power ZigbeeВ® and Thread With the SimpleLinkв„ў Wireless MCU Family
    PDF, 81 Кб, Файл опубликован: 27 фев 2018
  • Hardware Migration from CC26x0 to CC26x2R
    PDF, 29 Кб, Файл опубликован: 9 янв 2018
    This application report describes the required hardware changes when moving from the CC26x0 to the CC2642R or CC2652R SimpleLink™ wireless MCUs.
  • Ultra-Low Power Designs With the CC13x2 and CC26x2 Sensor Controller
    PDF, 87 Кб, Файл опубликован: 27 фев 2018
  • Getting Started With the CC13xx and CC26xx Sensor Controller
    PDF, 1.1 Мб, Файл опубликован: 6 окт 2017
    This application note is intended as an introduction to the low-power Sensor Controller Engine found in theCC13xx and CC26xx devices. It explains the benefits of using the Sensor Controller in various use cases.The application note also describes how to get started using the Sensor Controller and directs you to therequired tools and collaterals.
Серия: CC2652R (3)
  • Semiconductors > Wireless Connectivity > SimpleLink Solutions > Thread
На английском языке: Datasheet Texas Instruments CC2652R1FRGZT
