Оптопары и оптореле Megawin
Datasheet Texas Instruments CC2642R1FRGZR — Даташит
СерияCC2642R
МодельCC2642R1FRGZR
SimpleLink Bluetooth Low energy CC2642R беспроводной микроконтроллер 48-VQFN -40 до 85
CC2642R SimpleLink Bluetooth 5 low energy Wireless MCU datasheet
PDF, 1.0 Мб, Файл опубликован: 16 янв 2018
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)7
Length (мм)7
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
Bluetooth StandardBluetooth 5.0
Data Rate(Max)5000 kbps
Device TypeSimpleLink Wireless MCU
GPIO31
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Pin/Package48VQFN
RX Current (Lowest)6.5 мА
Security EnablerCryptographic acceleration,Debug security,Device identity,Software IP protection
TechnologyBluetooth low energy
Throughput(Max)5 Mbps
RoHSSee ti.com
  • Debug Probes/Analyzers: TMDSEMU200-U
    XDS200 USB Debug Probe
  • Evaluation Modules & Boards: LAUNCHXL-CC26X2R1
    SimpleLink Multi-Standard CC26x2R Wireless MCU LaunchPad Development Kit
  • Hardware Migration from CC26x0 to CC26x2R
    PDF, 29 Кб, Файл опубликован: 9 янв 2018
    This application report describes the required hardware changes when moving from the CC26x0 to the CC2642R or CC2652R SimpleLink™ wireless MCUs.
  • Ultra-Low Power Designs With the CC13x2 and CC26x2 Sensor Controller
    PDF, 87 Кб, Файл опубликован: 27 фев 2018
  • Getting Started With the CC13xx and CC26xx Sensor Controller
    PDF, 1.1 Мб, Файл опубликован: 6 окт 2017
    This application note is intended as an introduction to the low-power Sensor Controller Engine found in theCC13xx and CC26xx devices. It explains the benefits of using the Sensor Controller in various use cases.The application note also describes how to get started using the Sensor Controller and directs you to therequired tools and collaterals.
Серия: CC2642R (3)
  • Semiconductors > Wireless Connectivity > SimpleLink Solutions > Bluetooth Low Energy
На английском языке: Datasheet Texas Instruments CC2642R1FRGZR
