Datasheet Texas Instruments MSP432P4011 — Даташит
СерияMSP432P4011
SimpleLink Микроконтроллер смешанного сигнала
MSP432P411x, MSP432P401x SimpleLink Mixed-Signal Microcontrollers datasheet
PDF, 3.5 Мб, Версия: A, Файл опубликован: 2 фев 2018
MSP432P4011IRGCRMSP432P4011IRGCT
N12
Pin6464
Package TypeRGCRGC
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY2000250
CarrierLARGE T&RSMALL T&R
Width (мм)99
Length (мм)99
Thickness (мм)0.880.88
Pitch (мм)0.50.5
Max Height (мм)11
Parameters / ModelsMSP432P4011IRGCR
MSP432P4011IRGCR
MSP432P4011IRGCT
MSP432P4011IRGCT
ADC Channels1212
ADC Resolution, Bits1414
ADC Sampling Rate, MSPS11
Active Power, uA/MHz100100
CANN/AN/A
Comparators22
DMA88
Device TypeSimpleLink Host MCUSimpleLink Host MCU
EthernetN/AN/A
Flash, KB20482048
Тактовая частота, МГц4848
GPIO4848
I2C33
LCDN/AN/A
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupVQFNVQFN
RAM256256
RX Current (Lowest), мАN/AN/A
SPI66
Security EnablerCryptographic acceleration,Debug security,Device identity,Secure FW and SW update,Software IP protectionCryptographic acceleration,Debug security,Device identity,Secure FW and SW update,Software IP protection
Serial I/O66
Standby Current, uA0.820.82
TechnologyHost MCUsHost MCUs
Throughput(Max), MbpsN/AN/A
Timers55
UART33
USBN/AN/A
Vcc range, В1.62,3.71.62,3.7
RoHSСовместимСовместим
  • SimpleLink MSP432P4 - Smart Metering Host
    PDF, 125 Кб, Файл опубликован: 20 фев 2018
  • SimpleLink MSP432P4 - Low-Power 2MB MCU
    PDF, 64 Кб, Файл опубликован: 12 фев 2018
  • Designing an Ultra-Low-Power (ULP) Application With SimpleLink MSP432 MCUs (Rev. A)
    PDF, 487 Кб, Версия: A, Файл опубликован: 7 мар 2017
    With the growing system complexity in ultra-low-power microcontroller (MCU) applications minimizing the overall energy consumption is one of the most difficult problems to solve. Multiple aspects including silicon other onboard hardware components and application software must be considered. There are some obvious generic techniques that can be used to reduce energy consumption such as reducing
  • Low-Power Analog Measurements With SimpleLink MSP432 Microcontollers (Rev. A)
    PDF, 538 Кб, Версия: A, Файл опубликован: 19 окт 2017
    Ultra-low-power analog measurements are a common requirement in applications such as non-contact power measurement and wireless condition monitoring. Many of these systems are battery based and must achieve extended life while still providing continuous coverage. This application note describes how to utilize the low-power features of the analog-to-digital converter (ADC) with up to 16-bit precisi
  • Precision ADC With 16-Bit Performance
    PDF, 681 Кб, Файл опубликован: 11 янв 2018
  • Scaling Across the SimpleLink MSP432P4 MCU Family
    PDF, 385 Кб, Файл опубликован: 12 янв 2018
  • Leveraging Precision ADC on SimpleLink MSP432 MCUs for Predictive Maintenance (Rev. A)
    PDF, 506 Кб, Версия: A, Файл опубликован: 18 сен 2017
    This application report describes a high-performance method for predictive maintenance of motors by monitoring their frequency response with the SimpleLink MSP432P401R microcontroller using precision ADC with up to 16-bit ENOB and FFT analysis.
  • Migrating to the SimpleLink MSP432 Family (Rev. D)
    PDF, 366 Кб, Версия: D, Файл опубликован: 19 окт 2017
    The 16-bit MSP430 and the 32-bit SimpleLink MSP432 microcontroller (MCU) families complement each other in low-power and performance. The goal of this migration guide is to help developers accurately assess the effort to migrate an existing application from the 16-bit MSP430 to the 32-bit SimpleLink MSP432 Arm platform if they so choose to. Ultimately the migration guide is built to help derive a
Серия: MSP432P4011 (2)
  • Semiconductors > Microcontrollers (MCU) > SimpleLink MCUs > SimpleLink Wired MCUs
На английском языке: Datasheet Texas Instruments MSP432P4011
