Datasheet Texas Instruments MSP432P401VIRGCT — Даташит
СерияMSP432P401V
МодельMSP432P401VIRGCT
Микроконтроллер смешанных сигналов SimpleLink 64-VQFN от -40 до 85
MSP432P411x, MSP432P401x SimpleLink Mixed-Signal Microcontrollers datasheet
PDF, 3.5 Мб, Версия: A, Файл опубликован: 2 фев 2018
IC MCU 64VQFN. ARM® Cortex®-M4F MSP432TM SimpleLinkTM Microcontroller IC 32-Bit 48MHz 512KB (512K x 8) FLASH 64-VQFN (9x9). Embedded...
Рутоника
MSP432P401VIRGCT
454 ₽
MSP432P401VIRGCT
961 ₽
MSP432P401VIRGCT
Hi-Tech Circuit Group
MSP432P401VIRGCT
Pin64
Package TypeRGC
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Width (мм)9
Length (мм)9
Thickness (мм)0.88
Pitch (мм)0.5
Max Height (мм)1
ADC Channels12
ADC Resolution14 Bits
ADC Sampling Rate1 MSPS
Active Power100 uA/MHz
CANN/A
Comparators2
DMA8
Device TypeSimpleLink Host MCU
EthernetN/A
Flash512 KB
Тактовая частота48 МГц
GPIO48
I2C3
LCDN/A
Package GroupVQFN
RAM128
RX Current (Lowest)N/A мА
SPI6
Security EnablerCryptographic acceleration,Debug security,Device identity,Secure FW and SW update,Software IP protection
Serial I/O6
Standby Current0.82 uA
TechnologyHost MCUs
Throughput(Max)N/A Mbps
Timers5
UART3
USBN/A
Vcc range1.62,3.7 В
  • Development Kits: MSP-EXP432P4111
    SimpleLink MSP432P4111 MCU LaunchPad Development Kit
  • Debug Probes/Analyzers: MSP432-DEBUGGERS
    Debuggers for MSP432
  • Evaluation Modules & Boards: LAUNCHXL-CC1310
    SimpleLink Sub-1 GHz CC1310 wireless MCU LaunchPad development kit
  • Development Kits: CC3120BOOST
    SimpleLink™ Wi-Fi® CC3120 Wireless Network Processor BoosterPack™ Plug-In Module
  • Debug Probes/Analyzers: TMDSEMU110-U
    XDS110 JTAG Debug Probe
  • Development Kits: LAUNCHXL-CC2640R2
    SimpleLink™ Bluetooth® low energy CC2640R2F wireless MCU LaunchPad™ development kit
  • Evaluation Modules & Boards: MSP-TS432PZ100
    100-pin Target Development Board for SimpleLink™ MSP432P4x MCUs (microcontroller not included)
  • Designing an Ultra-Low-Power (ULP) Application With SimpleLink MSP432 MCUs (Rev. A)
    PDF, 487 Кб, Версия: A, Файл опубликован: 7 мар 2017
    With the growing system complexity in ultra-low-power microcontroller (MCU) applications minimizing the overall energy consumption is one of the most difficult problems to solve. Multiple aspects including silicon other onboard hardware components and application software must be considered. There are some obvious generic techniques that can be used to reduce energy consumption such as reducing
  • Low-Power Analog Measurements With SimpleLink MSP432 Microcontollers (Rev. A)
    PDF, 538 Кб, Версия: A, Файл опубликован: 19 окт 2017
    Ultra-low-power analog measurements are a common requirement in applications such as non-contact power measurement and wireless condition monitoring. Many of these systems are battery based and must achieve extended life while still providing continuous coverage. This application note describes how to utilize the low-power features of the analog-to-digital converter (ADC) with up to 16-bit precisi
  • Precision ADC With 16-Bit Performance
    PDF, 681 Кб, Файл опубликован: 11 янв 2018
  • Scaling Across the SimpleLink MSP432P4 MCU Family
    PDF, 385 Кб, Файл опубликован: 12 янв 2018
  • Leveraging Precision ADC on SimpleLink MSP432 MCUs for Predictive Maintenance (Rev. A)
    PDF, 506 Кб, Версия: A, Файл опубликован: 18 сен 2017
    This application report describes a high-performance method for predictive maintenance of motors by monitoring their frequency response with the SimpleLink MSP432P401R microcontroller using precision ADC with up to 16-bit ENOB and FFT analysis.
  • Migrating to the SimpleLink MSP432 Family (Rev. D)
    PDF, 366 Кб, Версия: D, Файл опубликован: 19 окт 2017
    The 16-bit MSP430 and the 32-bit SimpleLink MSP432 microcontroller (MCU) families complement each other in low-power and performance. The goal of this migration guide is to help developers accurately assess the effort to migrate an existing application from the 16-bit MSP430 to the 32-bit SimpleLink MSP432 Arm platform if they so choose to. Ultimately the migration guide is built to help derive a
Серия: MSP432P401V (2)
  • Semiconductors > Microcontrollers (MCU) > SimpleLink MCUs > SimpleLink Wired MCUs
На английском языке: Datasheet Texas Instruments MSP432P401VIRGCT
