Datasheet Texas Instruments TPS65268QRHBRQ1 — Даташит
| Серия | TPS65268-Q1 |
| Модель | TPS65268QRHBRQ1 |
Тройной синхронный понижающий преобразователь 4 В в 8 В, 3 А, 2 А 32-VQFN -40 в 125
TPS65268-Q1 4-V to 8-V, 3-A, 2-A, 2-A Triple Synchronous Step-Down Converter datasheet
PDF, 3.0 Мб, Версия: A, Файл опубликован: 30 янв 2018
Купить TPS65268QRHBRQ1 на РадиоЛоцман.Цены — от 63 до 435 ₽10 предложений от 10 поставщиков IC REG BCK ADJ 3A/2A TRPL 32VQFN. Buck Switching Regulator IC Positive Adjustable 0.6V 3 Output 3A, 2A 32-VFQFN Exposed Pad.... | |||
| TPS65268QRHBRQ1 Texas Instruments | 170 ₽ | ||
| TPS65268QRHBRQ1 Texas Instruments | 351 ₽ | ||
| TPS65268QRHBRQ1 Texas Instruments | 435 ₽ | ||
| TPS65268QRHBRQ1 Texas Instruments | по запросу | ||
| Pin | 32 |
| Package Type | RHB |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Width (мм) | 5 |
| Length (мм) | 5 |
| Thickness (мм) | 0.9 |
| Pitch (мм) | 0.5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| Control Mode | Current Mode |
| Duty Cycle(Max) | 100 % |
| Основные особенности | Enable,Forced Pulse Width Modulation (FPWM) Mode,Frequency Synchronization,Over Current Protection,Power Good,Synchronous Rectification,Tracking,UVLO Adjustable |
| Iout(Max) | 3 A |
| Iq(Typ) | 0.6 мА |
| Package Group | VQFN |
| Rating | Automotive |
| Regulated Outputs | 3 |
| Switching Frequency(Max) | 2300 kHz |
| Switching Frequency(Min) | 200 kHz |
| Тип | Converter |
| Vin(Max) | 8 В |
| Vin(Min) | 4 В |
| Vout(Max) | 6 В |
| Vout(Min) | 0.6 В |
- Low Conducted EMI Power Solution for Automotive Digital Cockpit With LMR14050 anPDF, 1.9 Мб, Файл опубликован: 7 фев 2018
For automotive electronics a challenge is electromagnetic interference (EMI). The circuit schematic andprinted circuit board (PCB) are critical to achieving excellent EMI performance for the power rail in theautomotive digital cockpit. Therefore knowing how to choose the IC and design the circuit has the mostsignificant impact while knowing how to optimize the board layout is also pivotal
Серия: TPS65268-Q1 (2)
- TPS65268QRHBRQ1 TPS65268QRHBTQ1
- Semiconductors > Power Management > DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
