Datasheet Texas Instruments TPS65268QRHBTQ1 — Даташит
СерияTPS65268-Q1
МодельTPS65268QRHBTQ1
Тройной синхронный понижающий преобразователь 4 В в 8 В, 3 А, 2 А 32-VQFN -40 в 125
TPS65268-Q1 4-V to 8-V, 3-A, 2-A, 2-A Triple Synchronous Step-Down Converter datasheet
PDF, 3.0 Мб, Версия: A, Файл опубликован: 30 янв 2018
30 предложений от 13 поставщиков
Рутоника
TPS65268QRHBTQ1
249 ₽
TPS65268QRHBTQ1
307 ₽
TPS65268QRHBTQ1
421 ₽
Hi-Tech Circuit Group
TPS65268QRHBTQ1
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
Control ModeCurrent Mode
Duty Cycle(Max)100 %
Основные особенностиEnable,Forced Pulse Width Modulation (FPWM) Mode,Frequency Synchronization,Over Current Protection,Power Good,Synchronous Rectification,Tracking,UVLO Adjustable
Iout(Max)3 A
Iq(Typ)0.6 мА
Package GroupVQFN
RatingAutomotive
Regulated Outputs3
Switching Frequency(Max)2300 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)8 В
Vin(Min)4 В
Vout(Max)6 В
Vout(Min)0.6 В
  • Low Conducted EMI Power Solution for Automotive Digital Cockpit With LMR14050 an
    PDF, 1.9 Мб, Файл опубликован: 7 фев 2018
    For automotive electronics a challenge is electromagnetic interference (EMI). The circuit schematic andprinted circuit board (PCB) are critical to achieving excellent EMI performance for the power rail in theautomotive digital cockpit. Therefore knowing how to choose the IC and design the circuit has the mostsignificant impact while knowing how to optimize the board layout is also pivotal
Серия: TPS65268-Q1 (2)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS65268QRHBTQ1
