Datasheet Texas Instruments TPS65680RSNT — Даташит
СерияTPS65680
МодельTPS65680RSNT
2-входовой, 18-канальный настраиваемый преобразователь уровня с OCP для дисплеев GOA/GIP 32-QFN -40 to 85
TPS65680 18-Channel Pattern-Programmable Level Shifter with Overcurrent Protection datasheet
PDF, 2.0 Мб, Версия: A, Файл опубликован: 8 янв 2018
15 предложений от 9 поставщиков
IC TRNSLTR BIDIRECTIONAL 32WQFN. Voltage Level Translator Bidirectional 1 Circuit 18 Channel 32-WQFN (4x4). Logic - Translators, Level Shifters
TPS65680RSNT
от 300 ₽
TPS65680RSNT
418 ₽
TPS65680RSNT
от 649 ₽
Hi-Tech Circuit Group
TPS65680RSNT
Pin32
Package TypeRSN
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
Width (мм)4
Length (мм)4
Thickness (мм)0.75
Pitch (мм)0.4
Max Height (мм)0.8
DisplayTypeAutomotive,LCD Bipolar,LCD Unipolar
IC IntegrationLCD Level shifter
Level Shifter/Scan Driver18 Ch
Pin/Package32QFN
Special FunctionAdjustable Sequencing,Charge Sharing,GPM/GVS,I2C I/F,Level Shifter,Output Discharge
Target Application13 to 21 inches,21 inches and above
  • Evaluation Modules & Boards: TPS65680EVM
    TPS65680 Programmable Level Shifter Evaluation Module
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65680 (2)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65680RSNT
