Datasheet Texas Instruments XLMG1210RVRT — Даташит
СерияLMG1210
МодельXLMG1210RVRT
Полумостовой GaN-драйвер 200 В, 1,5 А/3 А с регулируемым мертвым временем 19-WQFN от -40 до 125
LMG1210 200-V, 1.5-A, 3-A Half-Bridge GaN Driver With Adjustable Dead Time datasheet
PDF, 596 Кб, Файл опубликован: 14 фев 2018
GaN Driver with Adjustable Dead Time Half-Bridge Dual-Channel 200V 1.5A 19-Pin WQFN T/R
XLMG1210RVRT
Pin19
Package TypeRVR
Package QTY250
CarrierSMALL T&R
Width (мм)4
Length (мм)3
Thickness (мм)0.75
Bus Voltage200 В
Driver ConfigurationHalf Bridge
Fall Time0.5 нс
Input ThresholdTTL
Input VCC(Max)18 В
Input VCC(Min)6 В
Количество каналов2
Package GroupWQFN
Package Size: mm2:W x L19WQFN: 12 mm2: 4 x 3(WQFN) PKG
Peak Output Current3 A
Power SwitchMOSFET,GaNFET
Prop Delay10 нс
Rise Time0.5 нс
RoHSSee ti.com
  • Evaluation Modules & Boards: LMG1210EVM-012
    LMG1210 Half-bridge Open Loop Evaluation Module
  • Optimizing Efficiency Through Dead Time Control With the LMG1210 GaN Driver
    PDF, 139 Кб, Файл опубликован: 14 фев 2018
    Dead time is an extremely important design parameter in some high-frequency converters using GaN.Dead time becomes ever more important as the frequency of operation increases. This reportdemonstrates the need for dead time optimization by measuring efficiency of a converter with varyingdead times. This report also discusses the various sources of propagation delay mismatch which causedead
Серия: LMG1210 (3)
  • Semiconductors > Power Management > Gallium Nitride (GaN) Solutions > GaN FET Drivers
На английском языке: Datasheet Texas Instruments XLMG1210RVRT
