Datasheet Texas Instruments UCC35701N — Даташит
СерияUCC35701
МодельUCC35701N
Широтно-импульсный модулятор расширенного режима напряжения 14-PDIP 0–70
Advanced Voltage Mode Pulse Width Modulator datasheet
PDF, 984 Кб, Версия: C, Файл опубликован: 17 июн 2005
42 предложений от 24 поставщиков
IC REG CTRLR PWN VM 14DIP. Converter Offline Boost, Buck, Flyback, Forward Topology 700kHz 14-PDIP. PMIC - AC DC Converters, Offline...
Microfind
UCC35701N
от 329 ₽
Рутоника
UCC35701N
419 ₽
UCC35701NE4
UCC35701N
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY25
МаркировкаUCC35701N
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodFeedforward,Voltage
Duty Cycle(Max)99 %
Frequency(Max)700 kHz
Gate Drive(Typ)1 A
Package GroupPDIP
Special FeaturesMulti-topology,Soft Start,Synchronization Pin
TopologyBoost,Buck,Flyback,Forward
UVLO Thresholds On/Off13/9 В
Vin(Max)400 В
Vin(Min)13 В
  • U-150 Applying the UCC3570 Voltage-Mode PWM Controller to Both Off-Line
    PDF, 568 Кб, Файл опубликован: 5 сен 1999
    The UCC3570 families of pulse-width modulators are for application in isolated switching supplies using primary-side control and a voltage-mode feedback loop. BiCMOS processing provides higher switching frequencies at lower quiescent current drain, while including innovations in both performance and protection features. Its versatility is demonstrated with the description of a 50W, wide input-volt
  • DN-62 Switching Power Supply Topology Voltage Mode vs. Current Mode
    PDF, 66 Кб, Файл опубликован: 5 сен 1999
    This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC35701N
