Datasheet Intersil EL7534IY-T7 — Даташит
Монолитный понижающий регулятор 600 мА
EL7534 Datasheet
PDF, 493 Кб, Версия: 2017-10-17, Файл закачен: 9 май 2018
![]() 10 предложений от 10 поставщиков Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 600mA 10-TFSOP, 10-MSOP (0.118, 3.00mm Width) | |||
EL7534IY-T7 Intersil | 66 ₽ | ||
EL7534IY-T7 Intersil | 172 ₽ | ||
EL7534IY-T7 Renesas | по запросу | ||
EL7534IY-T7 | по запросу |
Корпус | 10 Ld MSOP T+R |
Индекс корпуса | M10.118A |
Пиковая температура пайки | 240°C |
# of Outputs | 1 |
Control Type | Voltage Mode |
Description | Monolithic 600mA Step-Down Regulator |
IOUT (max) (A) | 0.6 |
IQ | 400 µA |
Max Duty Cycle (%) | See Datasheet |
POR | Yes |
Peak Efficiency (%) | 94 |
SYNCH Capability | No |
Switching Freq. (max) | 1.5 MHz |
Switching Freq. (min) | 1.5 MHz |
Topology | Buck |
VIN (max) (V) | 5.5 |
VIN (min) (V) | 2.5 |
VOUT (max) (V) | 5.5 |
VOUT (min) (V) | 0.8 |
Серия: EL7534 (6)
- EL7534IY EL7534IY-T13 EL7534IY-T7 EL7534IYZ EL7534IYZ-T13 EL7534IYZ-T7
- Power Management > Switching Regulators > Integrated FET Regulators
EL7534IYT7, EL7534IY T7
