HMC362
v04.0109 FREQUENCY DIVIDERS -CHIP 1 GaAs HBT MMIC
DIVIDE-BY-4, DC -11 GHz Typical Applications Features Prescaler for DC to X Band PLL Applications: Ultra Low SSB Phase Noise: -149 dBc/Hz • Satellite Communication Systems Wide Bandwidth • Fiber Optic Output Power: -6 dBm • Point-to-Point and Point-to-Multi-Point Radios Single DC Supply: +5V • VSAT Small Size: 1.30 x 0.69 x 0.1 mm Functional Diagram General Description
The HMC362 is a low noise Divide-by-4 Static Divider
with InGaP GaAs HBT technology that has a small
size of 1.30 x 0.69 mm. This device operates from DC
(with a square wave input) to 11 GHz input frequency
with a single +5V DC supply. The low additive SSB
phase noise of -149 dBc/Hz at 100 kHz offset helps the
user maintain good system noise performance. Electrical Specifi cations, TA = +25° C, 50 Ohm System, Vcc= 5V
Parameter Conditions Maximum Input Frequency
Minimum Input Frequency
Input Power Range Min. Typ. 11 12 Sine Wave Input. [1] Max. Units
GHz 0.2 0.5 GHz
dBm Fin = 1 to 8 GHz -15 >-20 +10 Fin = 8 to 11 GHz -10 >-15 +2 Output Power [2] Fin = 11 GHz -9 -6 Reverse Leakage Both RF Outputs Terminated 40 dB Pin = 0 dBm, Fin = 6 GHz -149 dBc/Hz Pin = 0 dBm, Fout = 882 MHz 100 ps 68 mA SSB Phase Noise (100 kHz offset)
Output Transition Time
Supply Current (Icc) [2] dBm
dBm [1] Divider will operate down to DC for square-wave input signal.
[2] When operated in low power mode (pin 8 floating). 1-8 For price,
delivery,
and to placeCorporation:
orders: Analog Devices, Inc.,
For price, delivery, and to place orders, please contact …
