Линейка продуктов KEEN SIDE
Datasheet Songle Relay SMIH (14FH) — Даташит
ПроизводительSongle Relay
СерияSMIH (14FH)
16. Сверхминиатюрное реле высокой мощности.
Datasheet SMIH
PDF, 3.7 Мб, Файл закачен: 11 июн 2018, Страниц: 2
Subminature High Power Relay 16A
SMIH-05VDC-FD-ASMIH-05VDC-FD-BSMIH-05VDC-FD-CSMIH-05VDC-FL-ASMIH-05VDC-FL-BSMIH-05VDC-FL-CSMIH-05VDC-SD-ASMIH-05VDC-SD-BSMIH-05VDC-SD-CSMIH-05VDC-SL-ASMIH-05VDC-SL-BSMIH-05VDC-SL-CSMIH-06VDC-FD-ASMIH-06VDC-FD-BSMIH-06VDC-FD-CSMIH-06VDC-FL-ASMIH-06VDC-FL-BSMIH-06VDC-FL-CSMIH-06VDC-SD-ASMIH-06VDC-SD-BSMIH-06VDC-SD-CSMIH-06VDC-SL-ASMIH-06VDC-SL-BSMIH-06VDC-SL-CSMIH-09VDC-FD-ASMIH-09VDC-FD-BSMIH-09VDC-FD-CSMIH-09VDC-FL-ASMIH-09VDC-FL-BSMIH-09VDC-FL-CSMIH-09VDC-SD-ASMIH-09VDC-SD-BSMIH-09VDC-SD-CSMIH-09VDC-SL-ASMIH-09VDC-SL-BSMIH-09VDC-SL-CSMIH-12VDC-FD-ASMIH-12VDC-FD-BSMIH-12VDC-FD-CSMIH-12VDC-FL-ASMIH-12VDC-FL-BSMIH-12VDC-FL-CSMIH-12VDC-SD-ASMIH-12VDC-SD-BSMIH-12VDC-SD-CSMIH-12VDC-SL-ASMIH-12VDC-SL-BSMIH-12VDC-SL-CSMIH-18VDC-FD-ASMIH-18VDC-FD-BSMIH-18VDC-FD-CSMIH-18VDC-FL-ASMIH-18VDC-FL-BSMIH-18VDC-FL-CSMIH-18VDC-SD-ASMIH-18VDC-SD-BSMIH-18VDC-SD-CSMIH-18VDC-SL-ASMIH-18VDC-SL-BSMIH-18VDC-SL-CSMIH-24VDC-FD-ASMIH-24VDC-FD-BSMIH-24VDC-FD-CSMIH-24VDC-FL-ASMIH-24VDC-FL-BSMIH-24VDC-FL-CSMIH-24VDC-SD-ASMIH-24VDC-SD-BSMIH-24VDC-SD-CSMIH-24VDC-SL-ASMIH-24VDC-SL-BSMIH-24VDC-SL-CSMIH-36VDC-FD-ASMIH-36VDC-FD-BSMIH-36VDC-FD-CSMIH-36VDC-FL-ASMIH-36VDC-FL-BSMIH-36VDC-FL-CSMIH-36VDC-SD-ASMIH-36VDC-SD-BSMIH-36VDC-SD-CSMIH-36VDC-SL-ASMIH-36VDC-SL-BSMIH-36VDC-SL-CSMIH-48VDC-FD-ASMIH-48VDC-FD-BSMIH-48VDC-FD-CSMIH-48VDC-FL-ASMIH-48VDC-FL-BSMIH-48VDC-FL-CSMIH-48VDC-SD-ASMIH-48VDC-SD-BSMIH-48VDC-SD-CSMIH-48VDC-SL-ASMIH-48VDC-SL-BSMIH-48VDC-SL-C
N123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596
Размеры, мм28.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.628.9×12.6×20.6
Parameters / ModelsSMIH-05VDC-FD-A
SMIH-05VDC-FD-A
SMIH-05VDC-FD-B
SMIH-05VDC-FD-B
SMIH-05VDC-FD-C
SMIH-05VDC-FD-C
SMIH-05VDC-FL-A
SMIH-05VDC-FL-A
SMIH-05VDC-FL-B
SMIH-05VDC-FL-B
SMIH-05VDC-FL-C
SMIH-05VDC-FL-C
SMIH-05VDC-SD-A
SMIH-05VDC-SD-A
SMIH-05VDC-SD-B
SMIH-05VDC-SD-B
SMIH-05VDC-SD-C
SMIH-05VDC-SD-C
SMIH-05VDC-SL-A
SMIH-05VDC-SL-A
SMIH-05VDC-SL-B
SMIH-05VDC-SL-B
SMIH-05VDC-SL-C
SMIH-05VDC-SL-C
SMIH-06VDC-FD-A
SMIH-06VDC-FD-A
SMIH-06VDC-FD-B
SMIH-06VDC-FD-B
SMIH-06VDC-FD-C
SMIH-06VDC-FD-C
SMIH-06VDC-FL-A
SMIH-06VDC-FL-A
SMIH-06VDC-FL-B
SMIH-06VDC-FL-B
SMIH-06VDC-FL-C
SMIH-06VDC-FL-C
SMIH-06VDC-SD-A
SMIH-06VDC-SD-A
SMIH-06VDC-SD-B
SMIH-06VDC-SD-B
SMIH-06VDC-SD-C
SMIH-06VDC-SD-C
SMIH-06VDC-SL-A
SMIH-06VDC-SL-A
SMIH-06VDC-SL-B
SMIH-06VDC-SL-B
SMIH-06VDC-SL-C
SMIH-06VDC-SL-C
SMIH-09VDC-FD-A
SMIH-09VDC-FD-A
SMIH-09VDC-FD-B
SMIH-09VDC-FD-B
SMIH-09VDC-FD-C
SMIH-09VDC-FD-C
SMIH-09VDC-FL-A
SMIH-09VDC-FL-A
SMIH-09VDC-FL-B
SMIH-09VDC-FL-B
SMIH-09VDC-FL-C
SMIH-09VDC-FL-C
SMIH-09VDC-SD-A
SMIH-09VDC-SD-A
SMIH-09VDC-SD-B
SMIH-09VDC-SD-B
SMIH-09VDC-SD-C
SMIH-09VDC-SD-C
SMIH-09VDC-SL-A
SMIH-09VDC-SL-A
SMIH-09VDC-SL-B
SMIH-09VDC-SL-B
SMIH-09VDC-SL-C
SMIH-09VDC-SL-C
SMIH-12VDC-FD-A
SMIH-12VDC-FD-A
SMIH-12VDC-FD-B
SMIH-12VDC-FD-B
SMIH-12VDC-FD-C
SMIH-12VDC-FD-C
SMIH-12VDC-FL-A
SMIH-12VDC-FL-A
SMIH-12VDC-FL-B
SMIH-12VDC-FL-B
SMIH-12VDC-FL-C
SMIH-12VDC-FL-C
SMIH-12VDC-SD-A
SMIH-12VDC-SD-A
SMIH-12VDC-SD-B
SMIH-12VDC-SD-B
SMIH-12VDC-SD-C
SMIH-12VDC-SD-C
SMIH-12VDC-SL-A
SMIH-12VDC-SL-A
SMIH-12VDC-SL-B
SMIH-12VDC-SL-B
SMIH-12VDC-SL-C
SMIH-12VDC-SL-C
SMIH-18VDC-FD-A
SMIH-18VDC-FD-A
SMIH-18VDC-FD-B
SMIH-18VDC-FD-B
SMIH-18VDC-FD-C
SMIH-18VDC-FD-C
SMIH-18VDC-FL-A
SMIH-18VDC-FL-A
SMIH-18VDC-FL-B
SMIH-18VDC-FL-B
SMIH-18VDC-FL-C
SMIH-18VDC-FL-C
SMIH-18VDC-SD-A
SMIH-18VDC-SD-A
SMIH-18VDC-SD-B
SMIH-18VDC-SD-B
SMIH-18VDC-SD-C
SMIH-18VDC-SD-C
SMIH-18VDC-SL-A
SMIH-18VDC-SL-A
SMIH-18VDC-SL-B
SMIH-18VDC-SL-B
SMIH-18VDC-SL-C
SMIH-18VDC-SL-C
SMIH-24VDC-FD-A
SMIH-24VDC-FD-A
SMIH-24VDC-FD-B
SMIH-24VDC-FD-B
SMIH-24VDC-FD-C
SMIH-24VDC-FD-C
SMIH-24VDC-FL-A
SMIH-24VDC-FL-A
SMIH-24VDC-FL-B
SMIH-24VDC-FL-B
SMIH-24VDC-FL-C
SMIH-24VDC-FL-C
SMIH-24VDC-SD-A
SMIH-24VDC-SD-A
SMIH-24VDC-SD-B
SMIH-24VDC-SD-B
SMIH-24VDC-SD-C
SMIH-24VDC-SD-C
SMIH-24VDC-SL-A
SMIH-24VDC-SL-A
SMIH-24VDC-SL-B
SMIH-24VDC-SL-B
SMIH-24VDC-SL-C
SMIH-24VDC-SL-C
SMIH-36VDC-FD-A
SMIH-36VDC-FD-A
SMIH-36VDC-FD-B
SMIH-36VDC-FD-B
SMIH-36VDC-FD-C
SMIH-36VDC-FD-C
SMIH-36VDC-FL-A
SMIH-36VDC-FL-A
SMIH-36VDC-FL-B
SMIH-36VDC-FL-B
SMIH-36VDC-FL-C
SMIH-36VDC-FL-C
SMIH-36VDC-SD-A
SMIH-36VDC-SD-A
SMIH-36VDC-SD-B
SMIH-36VDC-SD-B
SMIH-36VDC-SD-C
SMIH-36VDC-SD-C
SMIH-36VDC-SL-A
SMIH-36VDC-SL-A
SMIH-36VDC-SL-B
SMIH-36VDC-SL-B
SMIH-36VDC-SL-C
SMIH-36VDC-SL-C
SMIH-48VDC-FD-A
SMIH-48VDC-FD-A
SMIH-48VDC-FD-B
SMIH-48VDC-FD-B
SMIH-48VDC-FD-C
SMIH-48VDC-FD-C
SMIH-48VDC-FL-A
SMIH-48VDC-FL-A
SMIH-48VDC-FL-B
SMIH-48VDC-FL-B
SMIH-48VDC-FL-C
SMIH-48VDC-FL-C
SMIH-48VDC-SD-A
SMIH-48VDC-SD-A
SMIH-48VDC-SD-B
SMIH-48VDC-SD-B
SMIH-48VDC-SD-C
SMIH-48VDC-SD-C
SMIH-48VDC-SL-A
SMIH-48VDC-SL-A
SMIH-48VDC-SL-B
SMIH-48VDC-SL-B
SMIH-48VDC-SL-C
SMIH-48VDC-SL-C
Номинальное рабочее напряжение, В555555555555666666666666999999999999121212121212121212121212181818181818181818181818242424242424242424242424363636363636363636363636484848484848484848484848
Серия: SMIH (14FH) (96)
  • Household appliance relay
На английском языке: Datasheet Songle Relay SMIH (14FH)
