Datasheet Texas Instruments MSP430FR2355TRHAT — Даташит
СерияMSP430FR2355
МодельMSP430FR2355TRHAT
Микроконтроллер 24 МГц 105C ULP с 32 КБ FRAM, 4 КБ SRAM, 44 ввода-вывода, 12-битный АЦП, 12-битный ЦАП, операционный усилитель/программируемый усилитель 40-VQFN -40 до 105
MSP430FR235x, MSP430FR215x Mixed-Signal Microcontrollers datasheet
PDF, 1.6 Мб, Файл опубликован: 10 май 2018
Pin40
Package TypeRHA
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаFR2355
Width (мм)6
Length (мм)6
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
ADC12-bit SAR
ADC: Channels12
BootloaderUART BSL
Comparator Channels2
FeaturedFR2
Основные особенностиDAC,OpAmp,Real-Time Clock
GPIO Pins44
I2C2
Non-volatile Memory32 KB
Package GroupVQFN
Package Size: mm2:W x L40VQFN: 36 mm2: 6 x 6(VQFN) PKG
RAM4 KB
SPI4
Special I/ON/A
Timers - 16-bit4
UART2
USBNo
  • Evaluation Modules & Boards: MSP-TS430PT48
    Target Development Board for MSP430FR2355 MCU - 48-pin (microcontroller not included)
  • Evaluation Modules & Boards: MSP-EXP430FR2355
    MSP430FR2355 LaunchPad Development Kit
  • How to Use the Smart Analog Combo in MSP430 MCUs
    PDF, 486 Кб, Файл опубликован: 4 май 2018
    Operational amplifiers (Op Amps or OAs) are used extensively in sensing and measurement applications. MSP430 microcontrollers (MCUs) provide full signal chain implementation with the integrated Smart Analog Combo (SAC) to replace external Op Amps. The Smart Analog Combo is a configurable analog peripheral that includes a high-performance low-power Op Amp a programmable gain amplifier (PGA) with g
  • Migration From MSP430 FR58xx FR59xx and FR6xx to FR4xx and FR2xx
    PDF, 214 Кб, Файл опубликован: 4 май 2018
    This application report enables easy migration from the MSP430FR58xx MSP430FR59xx and MSP430FR6xx family to the MSP430FR4xx and MSP430FR2xx family. This report describes programming system and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • Semiconductors > Microcontrollers (MCU) > MSP430 Ultra-Low-Power MCUs > Value Line MCUs
На английском языке: Datasheet Texas Instruments MSP430FR2355TRHAT
