Datasheet Vishay BPW34 — Даташит
| Производитель | Vishay |
| Серия | BPW34 |
| Модель | BPW34 |
Кремниевый PIN-фотодиод
BPW34, BPW34S
www.vishay.com Vishay Semiconductors Silicon PIN Photodiode
FEATURES Package type: leaded Package form: top view Dimensions (L x W x H in mm): 5.4 x 4.3 x 3.2 Radiant sensitive area (in mm2): 7.5 High photo sensitivity High radiant sensitivity Suitable for visible and near infrared radiation Fast response times Angle of half sensitivity: П• = В± 65В° 94 8583 Compliant to RoHS Directive 2002/95/EC and in
accordance to WEEE 2002/96/EC
Note
** Please see document “Vishay Material Category Policy”:
www.vishay.com/doc?99902 DESCRIPTION
BPW34 is a PIN photodiode with high speed and high
radiant sensitivity in miniature, flat, top view, clear plastic
package. It is sensitive to visible and near infrared radiation.
BPW34S is packed in tubes, specifications like BPW34. APPLICATIONS High speed photo detector PRODUCT SUMMARY
Ira (μA) ϕ (deg) λ0.1 (nm) BPW34 50 ± 65 430 to 1100 BPW34S 50 ± 65 430 to 1100 PACKAGE FORM COMPONENT Note Test condition see table “Basic Characteristics” ORDERING INFORMATION
PACKAGING REMARKS BPW34 Bulk MOQ: 3000 pcs, 3000 pcs/bulk Top view BPW34S Tube MOQ: 1800 pcs, 45 pcs/tube Top view ORDERING CODE Note MOQ: minimum order quantity ABSOLUTE MAXIMUM RATINGS (Tamb = 25 В°C, unless otherwise specified)
PARAMETER TEST CONDITION Reverse voltage
Power dissipation Tamb ≤ 25 °C Junction temperature
Operating temperature range Thermal resistance junction/ambient Rev. 2.1, 23-Aug-11 VALUE VR 60 UNIT
V PV 215 mW Tj 100 В°C Tamb -40 to + 100 В°C
°C Tstg -40 to + 100 t≤3s Tsd 260 °C Connected with Cu wire, 0.14 mm2 RthJA 350 K/W Storage temperature range
Soldering temperature SYMBOL Document Number: 81521
1
For technical questions, contact: detectortechsupport@vishay.com
THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT
ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000 BPW34, BPW34S …
