Datasheet ТI TMS320C542PGE1-40 — Даташит
| Серия | TMS320C542 |
| Модель | TMS320C542PGE1-40 |
Цифровой сигнальный процессор 144-LQFP
TMS320C54x, LC54x, VC54x Fixed-Point Digital Signal Processors datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 30 мар 1999
- Interfacing the TLV1571/78 Analog-to-Digital Converter to the TMS320C542 DSPPDF, 192 Кб, Файл опубликован: 7 окт 1999
This application report presents a hardware solution for interfacing the TLV1571/TLV1578 10-bit, 1.25 MSPS low-power analog-to-digital converter (ADC) to the 16-bit fixed-point TMS320C542 digital signal processor (DSP). The report describes the interface hardware and C-callable software routines, which support communication between ADC and DSP. - Choosing an ADC and Op Amp for Minimum OffsetPDF, 72 Кб, Файл опубликован: 28 окт 1999
Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi - Interfacing the TLV1544/1548 Analog Digital Converter to Digital ProcessorsPDF, 266 Кб, Файл опубликован: 1 авг 1997
This Application Report describes the hardware and software requirements for interfacing an A/D converter to a DSP and to a MCU. The 10-bit A/D converter TLV1544 (4 analog input channels) and the TLV1548 (8 analog input channels) from Texas Instruments have been used to develop such interface. Example software code has been written showing how to program the DSP and the MCU to control the A/D conv - Extending Fixed-Point Dynamic RangesPDF, 35 Кб, Файл опубликован: 1 июн 1997
In many advanced control problems such as state estimators, Kalman filters and some high Q filters, the dynamic range/accuracy of the coefficient can sometimes be beyond the range of a Q15 number while the data value can be typically represented as a Q15 number.This document discusses how you can extend the fixed-point math dynamic range beyond the range of a Q15 number with a minimum of instr - Emulator Processor Access TimeoutPDF, 35 Кб, Файл опубликован: 1 июн 1997
This document discusses what would cause a "processor access timeout" message in the XDS510 emulator command window. Also discussed are issues related to the validity of the error message information.
Серия: TMS320C542 (2)
- TMS320C542PGE1-40 TMS320C542PGE2-40
- Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
TMS320C542PGE140, TMS320C542PGE1 40
