Datasheet Texas Instruments TMS320VC549PGE-100 — Даташит
СерияTMS320VC549
МодельTMS320VC549PGE-100
Процессор цифровых сигналов 144-LQFP от -40 до 100
TMS320VC549 Fixed-Point DSP datasheet
PDF, 856 Кб, Версия: G, Файл опубликован: 19 окт 2004
Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 100MHz 100MIPS 144Pin LQFP
TMS320VC549PGE100W
1 611 ₽
TMS320VC549PGE-100
от 3 302 ₽
Hi-Tech Circuit Group
TMS320VC549PGE-100
TMS320VC549PGE100-10
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка-100TMS320VC549PGE
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
  • Evaluation Modules & Boards: TMDSDSK5416
    TMS320C5416 DSP Starter Kit (DSK)
  • JTAG Emulators/ Analyzers: TMDSEMU560V2STM-U
    XDS200 USB Debug Probe
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • Migrating from TMS320VC549 to TMS320VC5409 (Rev. C)
    PDF, 77 Кб, Версия: C, Файл опубликован: 12 фев 2002
    This document describes issues of interest related to migration from the TMS320VC549 to the TMS320VC5409. The objective of this document is to indicate differences between the two devices. Functions that are identical between the two devices are not included. For detailed information on the specific functions of either device, refer to the device data sheets and/or the TMS320C54x DSP CPU and Perip
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > Other C5000 DSP
TMS320VC549PGE100, TMS320VC549PGE 100
На английском языке: Datasheet Texas Instruments TMS320VC549PGE-100
