Datasheet Texas Instruments TMS320LC203PZA — Даташит
| Серия | TMS320LC203 |
| Модель | TMS320LC203PZA |
Цифровой сигнальный процессор 100-LQFP
Digital Signal Processors datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 30 авг 1998
Купить TMS320LC203PZA на РадиоЛоцман.Цены — от 397 до 3 803 ₽19 предложений от 17 поставщиков Цифровой сигнальный процессор DSP, DSP Fixed-Point 16Bit 40MHz 20MIPS 100Pin LQFP | |||
| TMS320LC203PZA х микросхема | 1 125 ₽ | ||
| TMS320LC203PZA Texas Instruments | 1 598 ₽ | ||
| TMS320LC203PZA Texas Instruments | 3 803 ₽ | ||
| TMS320LC203PZA Texas Instruments | по запросу | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 100 |
| Package Type | PZ |
| Industry STD Term | LQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 90 |
| Carrier | JEDEC TRAY (5+1) |
| Маркировка | TMS320LC203PZA |
| Width (мм) | 14 |
| Length (мм) | 14 |
| Thickness (мм) | 1.4 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.6 |
| Mechanical Data | Скачать |
- Feature Phone Based on TMS320LC203PDF, 131 Кб, Файл опубликован: 1 апр 1997
This application report describes a feature phone design based on the TMS320LC203. The LC203 is a 3V member of the TMS320C2xx DSP family combining low cost and low power consumption with a computing power of 20 MIPS. Three independent onchip ports, UART, Serial Port and Parallel Port, allow designing with minimal external logic saving cost, board space and assuring fast access times.This report - Implementing Circular Buffers With Bit-Reversed AddressingPDF, 84 Кб, Файл опубликован: 1 июл 1997
Delay lines are used in many DSP applications. Delay lines provide a buffer of the last N samples of data for a filter or other algorithm. While delay lines can be implemented as linear or circular buffers, buffers of the circular variety are often preferred due to their relative simplicity.Texas Instruments' (TI) TMS320 family of DSPs can manipulate circular buffer pointers without penalty to
Серия: TMS320LC203 (2)
- TMS320LC203PZ TMS320LC203PZA
- Semiconductors > Processors > Other Processors
