Datasheet Texas Instruments TMS320VC5509PGE31 — Даташит
СерияTMS320VC5509
МодельTMS320VC5509PGE31
Процессор цифровых сигналов с фиксированной точкой 144-LQFP
TMS320VC5509 Fixed-Point Digital Signal Processor (Rev. H)
PDF, 1.7 Мб, Версия: H, Файл опубликован: 22 янв 2008
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаTMS320VC5509PGE31
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
Рекомендуемая замена
ReplacementTMS320VC5509APGE
Replacement CodeQ
RoHSНе совместим
  • Evaluation Modules & Boards: TMDX5502EZDSP
    C5502 eZdsp Development Kit
  • A DSP/BIOS MMC Device Driver for TMS320C5509 DSP (Rev. A)
    PDF, 134 Кб, Версия: A, Файл опубликован: 1 июн 2003
  • Programming the TMS320VC5509 RTC Peripheral (Rev. A)
    PDF, 164 Кб, Версия: A, Файл опубликован: 25 сен 2002
    This application report demonstrates the procedure used to program the TMS320VC5509 digital signal processor (DSP) Real Time Clock (RTC). Basic operations of the RTC, such as reading and writing the time, as well as interrupt configuration, are covered. All interaction with the peripheral is accomplished using the Chip Support Library (CSL) RTC module. An example that illustrates usage of these ro
  • Programming the TMS320VC5509 ADC Peripheral (Rev. A)
    PDF, 80 Кб, Версия: A, Файл опубликован: 26 фев 2010
  • A DSP/BIOS AIC23 Codec Device Driver for the TMS320C5509 DSK (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 дек 2003
  • Using the TMS320VC5509/5510 Enhanced HPI (Rev. A)
    PDF, 458 Кб, Версия: A, Файл опубликован: 19 май 2006
    The enhanced host port interface (EHPI) on the TMS320VC5509 and TMS320VC5510 DSPs provides a 16-bit port through which a host device may access the internal and external memory space of the DSP. The flexibility of the EHPI interface allows various host devices to interface with the DSP using minimal or no external interface logic. This document describes various possible EHPI configurations and ex
  • TMS320VC5509 to TMS320VC5509A Migration (Rev. C)
    PDF, 180 Кб, Версия: C, Файл опубликован: 10 сен 2004
    This document provides a summary of the differences between the TMS320VC5509 and TMS320VC5509A. All efforts have been made to provide a comprehensive list of the differences between the two devices, this will be updated if additional changes are identified.As the focus of this document is the differences between the two devices, the descriptions of the behavior and functions of the devices ar
  • Programming the TMS320VC5509 Multi Media Controller in Native Mode (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 6 июн 2003
    This document contains information and examples on accessing MMC/SD FLASH 7 cards through the C5509 MMC Controller operating in the native mode. The document provides an overview of the native mode functionality, including programming flow for the typical tasks that the user encounters when interfacing to the MMC cards in the native mode. For each operation, the procedures are highlighted with tab
  • Programming the TMS320VC5503/C5506/C5507/C5509/C5509A I2C Peripheral (Rev. A)
    PDF, 157 Кб, Версия: A, Файл опубликован: 26 сен 2008
    This application report demonstrates the procedure used to program the TMS320VC5503/C5506/C5507/C5509/C5509A inter-integrated circuit (I2C) peripheral module. Basic operations of the I2C, including reading and writing, and the initialization of the I2C bus are covered. These operations are illustrated using the I2C routines provided in the chip support library (CSL). For more information, see the
  • Disabling the Internal Oscillator on the TMSVC5503/C5506/C5507/C5509/C5509A DSP (Rev. D)
    PDF, 99 Кб, Версия: D, Файл опубликован: 9 сен 2008
    This application report contains information and examples on how to disable the internal clock oscillator on the TMS320VC5503, TMS320VC5506, TMS320VC5507, TMS320VC5509, and TMS320VC5509A DSPs to minimize power consumption. The document contains an overview of how the internal clock oscillator operates, and how to disable it as part of the IDLE power-down feature. It also discusses how to wake up t
  • Using the TMS320VC5506/C5507/C5509/C5509A USB Bootloader (Rev. C)
    PDF, 304 Кб, Версия: C, Файл опубликован: 1 окт 2008
    Bootloading the TMS320VC5506/C5507/C5509/C5509A digital signal processor (DSP) through the on-chip universal serial bus (USB) peripheral is part of the standard bootloader provided on the device. This document describes the procedures for physically connecting the DSP to a USB host, invoking the USB bootloader on the DSP, generating the correct boot table file, and downloading the boot table from
  • Using the TMS320VC5503/C5506/C5507/C5509/C5509A Bootloader (Rev. F)
    PDF, 222 Кб, Версия: F, Файл опубликован: 5 сен 2008
    This document describes the features of the on-chip bootloder provided with the TMS320VC5503/C5506/C5507/C5509/C5509A digital signal processor (DSP). Included are descriptions of each of the available boot modes and any interfacing requirements associated with them as well as instructions on generating the boot table.
Серия: TMS320VC5509 (2)
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMS320VC5509PGE31
